e-ManualTopSite mapHelp
Top » Problem Solving » List of Error Messages » Quick Menu
Quick Menu
0L3X-0U6
This section describes the error messages related to the Quick Menu function.
Error Messages Displayed on the Touch Panel Display
Cannot register new button because the number of registered buttons has reached the limit. Buttons already registered can be overwritten.
Cannot recall settings of the button because the function for the button does not exist.
Cannot recall settings of the button because other operations are in use.
Cannot recall the settings because the function for the button is disabled. Enable the function, then try again.
Register to Quick Menu will be canceled and you will be returned to the function screen because you do not have permission to register buttons. Log in as an administrator, then try again.
Register to Quick Menu will be canceled because you are not logged in. Return to the function screen, log in, then try again.
Cause
You tried to register more than the maximum number of Personal buttons/Shared buttons that can be registered.
Remedy
Delete any unnecessary buttons, and try registering again. (See "Editing a Personal Button/Shared Button.")
Cause
You tried to use the Personal button/Shared button imported from another imageRUNNER ADVANCE series machine that contains functions not supported by the machine.
Remedy
Create a Personal button/Shared button using the functions that are supported by your machine.
Cause
You tried to recall the settings registered in the Personal button/Shared button while the machine is processing another job.
Remedy
Wait a while, and try using the Personal button/Shared button again.
Cause
You tried to recall a button for a function that is stopped.
Remedy
Make the function that is stopped available for use, and try using the button again.
Cause
Registration of Personal buttons/Shared buttons is restricted.
Remedy
Log in as the administrator to register a button.
Cause
Registration of Shared buttons is restricted.
Remedy
Error Messages Displayed on the Web Browser
You do not have privileges to access the Quick Menu page.
Cannot import because the number of buttons for registration has exceeded the upper limit.
The device is currently being used by another user. Wait a while, and then try to perform the operation again.
The contents of the specified file may be incorrect.
The function may be stopped. Buttons could not be imported.
Cause
You tried to log in with a user name that does not have privileges.
Remedy
Try to log in with a user name that has privileges.
Cause
You tried to register more than the maximum number of Personal buttons/Shared buttons that can be registered when starting an import operation.
Remedy
Delete any unnecessary buttons, and try importing again.
Cause
Other user is using the device.
Remedy
Wait a while, and try again.
Cause
You specified a file different from the Quick Menu file when importing.
Remedy
Specify the correct file, and try importing again.
Cause
You imported a file containing buttons for functions that are not supported by your machine.
Remedy
Check the function status of your machine.
