e-ManualTopSite mapHelp
Top » Problem Solving » Clearing Paper Jams » Reducing the Frequency of Paper Jams
0UKW-072
If paper jams occur frequently, even though there is no apparent problem with the machine, either one of the following two reasons may be the cause. Follow the instructions described below to reduce the frequency of paper jams.
There are torn pieces of paper left inside the machine.
Pulling jammed paper out of the machine by force may leave parts of the paper torn inside, leading to frequent paper jams.
If paper tears while you are trying to remove jammed paper from the machine, make sure that you remove all of the torn pieces.
The paper is not loaded correctly in the paper drawer.
Make sure that the paper size label of the paper drawer matches the size of the paper loaded in the paper drawer.
