e-ManualTopSite mapHelp
Top » Problem Solving » Clearing Paper Jams » Locations of Paper Jams » Paper Sources
Paper Sources
0UKW-06X
If a paper jam occurs in a paper drawer, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
Optional products are required to use Paper Drawers 2, 3, and 4. (See "Optional Products Required for Each Function.")
If paper is loaded in the multi-purpose tray, remove the loaded paper.
