e-ManualTopSite mapHelp
Top » Problem Solving » List of Error Messages » Printer
Printer
0UKW-07A
If the machine is unable to print for some reason, the Error indicator lights up and a message indicating the cause of the problem is displayed on the touch panel display. When these messages are displayed, take the appropriate action to solve the problem.
If a message indicating another problem occurs at the same time as the first error message, a warning message will not be displayed.
For instructions on performing [Skip Error] from the touch panel display, see "Status Monitor/Cancel."
For instructions on canceling a print job from the touch panel display, see "Canceling Print Jobs."
<PDL Reg. Access Error>
Cause
A malfunction occurred and the printer cannot operate normally.
Remedy
Restart the machine. If the message does not disappear after restarting the machine, write down the message displayed on the touch panel display and contact your local authorized Canon dealer.
<PDL Data Transfer Error>
Cause
Remedy
<PDL nn Rendering Error> (Where "nn" is a module name)
Cause
Remedy
<PDL Rendering Timeout>
Cause
Remedy
<PDL Image Comp. Error>
Cause
Remedy
<PDL GL Mem. Alloc. Err>
Cause
Remedy
<PDL GL Range Check>
Cause
Remedy
<PDL GL Coord.Result>
Cause
Remedy
<PDL Invalid GL Input>
Cause
Remedy
<PDL GL Orig. Pt Unknown>
Cause
Remedy
<PDL GL Memory Full>
Cause
There is not enough work memory for system data processing (primarily figure processing and text processing).
Remedy
Perform [Skip Error] to continue processing. However, the output result of pages containing the relevant sections is not guaranteed.
<FM FONT MEMORY FULL>
Cause
Remedy
<FM DL FONT MEMORY FULL>
Cause
Remedy
<FM FILE ACCESS ERROR>
Cause
Remedy
<FM WORK MEMORY ERROR>
Cause
Remedy
<FM FONT PARSE ERROR>
Cause
Remedy
<FM ALIGNMENT ERROR>
Cause
Remedy
<FM SC WORK MEM. ERROR n> (Where "n" is a one digit number.)
Cause
Remedy
<FM DL SIZE ERROR n> (Where "n" is a one digit number.)
Cause
Remedy
<FM DL SCALE ERROR n> (Where "n" is a one digit number.)
Cause
Remedy
<PDL DLG Mem. Alloc. Err>
Cause
Remedy
<PDL DLG Rendering Error>
Cause
Remedy
<PDL Invalid DLG Input>
Cause
Remedy
<PDL DLG Unknown Error>
Cause
Remedy
<PDL DLG Memory Full>
Cause
Remedy
<PDL RIP Process. Error>
Cause
Remedy
<PDL PCL Initial. Error>
Cause
An error, such as not being able to obtain memory, occurred during initialization.
Remedy
Restart the machine and execute the job again. If this error persists, contact your local authorized Canon dealer.
<PDL PCL Process Error>
Cause
PCL processing failed.
Remedy
<PDL PCL Work Memory Full>
Cause
There is not enough work memory available.
Remedy 1
After canceling the print job, perform a printer reset to free up memory, then try printing again. (Note that all print data stored in memory, such as Secure Print jobs, and all print jobs being processed are deleted.)
Remedy 2
Perform [Skip Error] to continue printing. However, the data that is the source of the error will not be printed correctly.
<PDL PCL DL Memory Full>
Cause
There is not enough memory for downloading.
Remedy 1
Remedy 2
<PDL IMG Refer. Data Err>
Cause
The TIFF or JPEG data contains data that cannot be processed by this machine.
Remedy
After canceling the print job, perform a printer reset, then try printing again. (Note that all received data in the machine's memory is deleted.)
<PDL IMG Initial. Err>
Cause
An error occurred during the initialization of the function.
Remedy
Cancel the job and then perform a printer reset to initialize the function again. (See "Reset Printer.") If this error persists, contact your local authorized Canon dealer.
<PDL IMG Invalid Data>
Cause
There is data in the TIFF or JPEG images that cannot be processed by the machine.
Remedy
Cancel the job and try printing the data again.
<PDL IMG Process. Error>
Cause
An error occurred while processing data.
Remedy
<PDL IMG Work Memory Full>
Cause
There is not enough memory necessary to process TIFF or JPEG images.
Remedy
<PDL PDF Data Decode Err>
Cause 1
The password you entered to print the PDF file is incorrect.
Remedy
Enter the correct password from the Remote UI and print the data again.
Cause 2
The Security settings in the PDF file do not allow printing.
Remedy
Change the setting to allow printing.
Cause 3
The policy server cannot be accessed from a PDF linked to the policy server.
Remedy
Confirm whether the policy server is turned ON, and check the status of the machine, policy server, and network. (See "Printing Files Directly From the Remote UI.")
<PDL PDF Error>
Cause
PDF data that cannot be processed by the machine was sent.
Remedy
Contact your local authorized Canon dealer.
<PDL PDF Memory Full>
Cause
The machine's memory space allocated for PDF is full and printing cannot proceed.
Remedy 1
After canceling the print job, optimize the PDF in Adobe Acrobat and reduce the size of the data you are going to print at one time, such as by resetting the resolution to an appropriate level, and try printing again. (See the Adobe Acrobat Help.)
Remedy 2
After canceling the print job, reduce the number of pages to print at one time by dividing the PDF data you are going to print in Adobe Acrobat into several files, before trying to print again. (See the Adobe Acrobat Help.)
Remedy 3
After canceling the print job, open the data in the application software and print again via the printer driver. (See the Adobe Acrobat Help.)
<PDL PDF Font Error>
Cause
The PDF data contains a font that cannot be printed by this machine.
Remedy
Cancel printing, and perform printing again using PDF data in a format compatible with this machine.
<PDL PDF Print Range Err>
Cause
The range of the specified print pages is incorrect.
Remedy
After canceling the print job, check the number of pages in the PDF data, then specify the correct printing range and try printing again.
This error will not be displayed if there are printable pages within the printing range you specified. For example, if a PDF data has five pages in it, and you specify a printing range from page 2 to 10, then page 2 to 5 will be printed without an error being displayed.
<PDL UFR II Version Err>
Cause
The machine received data from an incompatible UFR II version.
Remedy 1
Install a UFR II printer driver for use with the imageRUNNER ADVANCE C350P and print the data again.
Remedy 2
Perform [Skip Error] and continue printing. However, the data will not be printed correctly.
<PDL UFR II Work Mem Full>
Cause
The work memory for the UFR II mode is full.
Remedy 1
After canceling the print job, reset the printer to increase the amount of available memory and print again. (Note that print data in memory such as secure print jobs and any jobs being processed will be deleted.) (See "Reset Printer.")
Remedy 2
If you set [Auto Error Skip] to [On], this error is skipped automatically. (See "Auto Error Skip.")
<PDL UFR II Admin Error>
Cause
Remedy
<PDL UFR II Area Error>
Cause
Remedy
Cause
Remedy 1
Remedy 2
<XPS Memory Full>
Cause
There is not enough memory for processing XPS data.
Remedy
<XPS Spool Memory Full>
Cause
Remedy
Restart the machine and execute the job again. If printing still cannot be performed, divide the data into several sections by setting page ranges etc., and print the sections separately.
<XPS Font Error>
Cause
Analysis of the font data failed.
Remedy
Replace the font data in the XPS file and try printing again.
<XPS Print Range Error>
Cause
There are no pages that can be processed within the specified print range.
Remedy
Specify the correct page range.
<XPS Data Error>
Cause
An unsupported data format is included.
Remedy
Change the format of the image data to TIFF or JPEG and try printing again.
<XPS Unsupport Image Err>
Cause
Remedy
<XPS Page Data Error>
Cause
The page could not be generated due to incorrect content.
Remedy
Try printing again using XPS data in a format compatible with the machine.
<XPS Image Data Error>
Cause
Expansion of the image data failed.
Remedy
Replace the image data in the XPS file and try printing again.
<PDL XPS Rendering Error>
Cause
An error occurred in the rendering system.
Remedy
