e-ManualTopSite mapHelp
Top » Problem Solving » Service Call Message
0UKW-075
If a malfunction occurs and the machine cannot operate normally, a screen prompting you to contact your local authorized Canon dealer is displayed.
If a screen such as the one above is displayed, contact your local authorized Canon dealer. (See "Contacting Your Local Authorized Canon Dealer.")
When [Limited Func. Mode] is displayed:
If [Limited Func. Mode] is displayed, you can temporally set the Limited Functions Mode to continue to use the machine until the cause of the malfunction is cleared. (See "Setting the Limited Functions Mode from the Service Call Message Screen.")
If a screen such as the one below is displayed and the print function does not operate normally, some functions may still be available.
When the Print function does not operate normally:
The selected function cannot be used. Press [Main Menu] to return to the Main Menu.
When a service call message is displayed on the bottom of the screen:
Even if a message prompting you to call your service representative appears on the bottom of the screen, some functions may still be available. (See "Functions Available When the Printer Cannot Be Used Due to an Error.")
If a screen prompting you to contact your local authorized Canon dealer is displayed, follow the procedure described below.
Turn the main power OFF and then ON.
For precautions to take when restarting the machine, see "Main Power and Energy Saver Key."
If the operation still cannot be performed correctly, turn the main power switch OFF, remove the power plug from the outlet, and contact your local authorized Canon dealer.
WARNING
Do not connect or disconnect the power cord with wet hands, as this may result in electrical shock.
CAUTION
Always grasp the power plug when disconnecting the power cord. Pulling on the power cord may expose or snap the core wire, or otherwise damage the power cord. If the power cord is damaged, this could cause current to leak, resulting in a fire or electrical shock.
When you contact your local authorized Canon dealer, have the following information available:
Product name
Details of the malfunction
The error code displayed on the touch panel display
When [Limited Func. Mode] is displayed, follow the procedures below.
If you turn OFF the main power switch when there is a job waiting to print, that job is erased.
If you set Limited Functions Mode to 'On' from the Service Call Message screen, [Limited Functions Mode] in [Management Settings] (Settings/Registration) is also set to 'On'. (See "Limiting Functions.")
Press [Limited Func. Mode] → [Yes].
A message prompting you to restart the machine (turning the main power switch OFF, and then ON) appears.
You can use the following functions even when the Print function is restricted.
Main Menu Screen
: Available
-: Unavailable
Available Functions
When the Print function is restricted:
Access Stored Files
Secure Print
Web Access
Shortcut to Settings/Registration
Other MEAP Applications*1
*1 Available by installing each MEAP application. May not be available depending on the restricted functions.
Touch Panel Display Left Side
: Available
-: Unavailable
Available Functions
Quick Menu*1
The Status Monitor/Cancel Screen
*2
*1 The registered button may not be available depending on the restricted functions.
*2 [Print List] on the Job Log screen and [Register] on the Consumable screen are not available.
Control Panel
: Available
-: Unavailable
Available Functions
Operation from a Computer
: Available
-: Unavailable
Available Functions
Remote UI*1
MEAP Application*2
*1
Some of the menus may not be available depending on the restricted functions.
*2
A print job is automatically canceled when the Print function is restricted.
The machine may not enter the Sleep mode completely when a function is restricted due to an error.
If the target function is restricted due to an error, the function is not available when you use the shortcut key on the left side of the touch panel display or when you use the Quick Menu.
