e-ManualTopSite mapHelp
Top » Problem Solving » Clearing Paper Jams » Locations of Paper Jams » Paper Sources » Paper Drawer 2, 3, and 4
0UKW-070
Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
Optional products are required to use Paper Drawers 2, 3, and 4. (See "Optional Products Required for Each Function.")
Remove any paper jammed inside the right cover of the paper drawer.
1. Open the right cover of the paper drawer.
2. Remove any paper jammed inside the right cover of the paper drawer.
3. Close the right cover of the paper drawer.
CAUTION
When closing the right cover of the paper drawer, be careful not to get your fingers caught, as this may result in personal injury.
Remove any jammed paper from the paper drawer.
1. Pull out the paper drawer (2, 3, or 4).
2. Remove any jammed paper from the paper drawer.
Paper may be jammed in a location other than the paper drawer displayed on the touch panel display. Pull out each drawer and check whether there is any jammed paper.
Gently push the paper drawer back into the machine.
CAUTION
When returning the paper drawer to its original position, be careful not to get your fingers caught, as this may result in personal injury.
4.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
