Top » Scan and Store » Overview of This Function » Mail Box
Mail Box
0R9W-12C
The flow of basic scan and store operations is as follows.
Mail Box Selection Screen
On this screen, the numbers, names, and available memory are displayed for each mail box. Also, an icon indicating the status of the mail box and whether it is set with a PIN is displayed next to the mail box number.
The following icons are displayed on the Mail Box Selection screen:
 is the icon for an empty mail box.
 is the icon for a mail box with files.
 is the icon for a mail box that is set with a PIN.
File Selection Screen
Each icon indicates the color mode used when the file was stored and whether it was stored with print settings.
1
You can specify the following settings:
Register to Quick Menu (See "Quick Menu.")
2
[Name]
Press to sort the files by name, in ascending or descending order.
[Date/Time]
Press to sort the files by date/time, in ascending or descending order.
3
[Display Image]
Press to view the contents of the selected file.
4
[Details]
Press to check the details of a file stored in a mail box.
5
[Scan]
Your original is scanned and stored in a mail box.
6
[Edit File/Other]
Press to edit or check a file in a mail box.
7
[Up]
Press to return to the upper level.
8
[Select All (Max 100 Files)]
Press to select all of the files in a mail box. If a file is selected, this key changes to [Clear Selection].
Edit File Screen
Display this screen when you want to edit a file in a folder.
1
[Delete]
 Press to delete a file stored in a mail box.
2
[Change File Name]
Press to change a file name.
3
[Print List]
Press to print a list of the files stored in a mail box.
Scan Screen
Display this screen when you want to scan an original and store it as a file in the selected folder.
1
Register/Edit Favorite Settings
Register to Quick Menu(See "Quick Menu.")
Change Default Settings
2
[Favorite Settings]
 Press to recall scan settings or register frequently used settings in the Favorite Settings.
3
[Scan Size]
Press to set the size of the original that you are going to scan.
4
[2-Sided Original]
Press if you are scanning a two-sided original.
5
[File Name]
Press to assign the file a name.
6
[Options]
Press to specify useful scan settings, such as scanning different size originals together or dividing originals into multiple batches.
7
[Restore Dflt. Set.]
Press to cancel all settings. (The machine restores the default settings for Scan and Store.)
8
[Original Type]
Press to select the type of original ([Text/Photo/Map], [Printed Image], [Photo Printout], or [Text]) you are going to scan.
9
[Density]
Press to adjust the density for scanning.
10
[Select Color]
Press to select the color for scanning.
You cannot store files in a mail box in the cases described below. (These numbers may vary depending on the remaining capacity of the memory.)
When more than 2,000 files are stored in the selected mail box.
When more than 2,000 files are stored in all of the mail boxes.
When a total of approximately 6,000 pages of files are stored in all of the mail boxes.
For more information on the icons displayed in the Mail Box, see "Types of Mail Box Icons."
We recommend that you delete unwanted files or image data from your Mail Box to make space for storing new files.
