Top » Scan and Store » Setting the File Format
0R9W-133
You can set the file format to use when scanning originals.
As an example, the procedure for selecting memory media as the storage location is explained in this section.
This mode is only available for storing files the Advanced Box of another imageRUNNER ADVANCE machine on the network or memory media.
Press [Scan and Store] → [Memory Media].
Select the memory media → select the destination folder → press [Scan].
Press [File Format] → select the desired file format.
[JPEG]:
Stores the file in the JPEG format only if you select a color mode other than [Black & White].
[TIFF]:
Stores the file in the TIFF format only if you select [Black & White] for the color mode.
[PDF]:
Stores the file in the PDF format regardless of the color mode. You can also select additional settings.
[XPS]:
Stores the file in the XPS format regardless of the color mode. You can also select additional settings.
[OOXML]:
Stores the file in the Office Open XML (pptx/docx) format only if you select the Full Color mode or the Grayscale mode for the color mode.
If you select [JPEG]:
If you select [TIFF], [PDF], [XPS], or [OOXML]:
Press [OK].
If you select [JPEG], [Divide into Pages] is set to 'On'.
Specify whether or not to divide your files into separate pages → press [OK].
If you want to separate multiple images and scan them as separate files, press [Divide into Pages]. If you want to store the images as a single file, set the setting to 'Off'.
You can select additional settings if you store the scanned file in the PDF, XPS, or OOXML format. Refer to the following for instructions on setting each type of PDF, XPS, or OOXML:
[Trace & Smooth]:Trace and Smooth
[OCR (Text Searchable)]:Searchable PDF/OOXML Files
[Apply Policy]:Applying a Policy
