Top » Scan and Store » Compact PDF or XPS Files
0R9W-135
This mode enables you to scan text originals or text/photo originals using a high compression ratio. If you select [Compact], it is recommended that you set the original type setting to either 'Text' or 'Text/Photo', depending on the image type.
As an example, the procedure for selecting memory media as the storage location is explained in this section.
This mode is only available for storing files the Advanced Box of another imageRUNNER ADVANCE machine on the network or memory media.
PDF (Compact) or XPS (Compact) is only valid with the following settings:
Select Color: Color mode other than the Black-and-White mode
Resolution: 300 x 300 dpi
Copy Ratio: 100% or Auto
Press [Scan and Store] → [Memory Media].
Select the memory media → select the destination folder → press [Scan].
Press [File Format] → select [PDF] or [XPS] → press [Set Details].
4.
Press [Compact] → [OK] → [OK] .
If you want to separate a document with multiple pages into separate pages and scan them as separate files, set [Divide into Pages] to 'On'. If you want to scan the images as a single file, set this setting to 'Off'.
If you select [Compact] for PDF or XPS file format, the color mode is changed from [Auto (Color/B&W)] and [Black & White] to [Auto (Color/Gray)] and [Grayscale]. If you want to scan the document with the color mode that you specify, change the PDF or XPS file format to anything other than [Compact] or [Trace & Smooth].
