Top » Scan and Store » Unavailable Combination of Functions
0R9W-13S
The following tables show the unavailable combinations of settings when you want to set more than one mode at a time.
Mail Box
Function
Functions that Cannot Be Used in Combination
Platen Glass Scanning
Feeder Scanning*1, 2-Sided Scanning
Feeder Scanning
Platen Glass Scanning*1, Book2 Pages
Document Size Auto Select
Document Size Manual Select*2, Original Frame Erase, Book Frame Erase
Document Size Auto Select*2, Different Size Originals
Text/Photo/Map
Photo Printout*2, Printed Image*2, Text*2
Photo Printout
Text/Photo/Map*2, Printed Image*2, Text*2
Printed Image
Text/Photo/Map*2, Photo Printout*2, Text*2
Text
Text/Photo/Map*2, Photo Printout*2, Printed Image*2
1-Sided Scanning
2-Sided Scanning*2
2-Sided Scanning
1-Sided Scanning*2, Book2 Pages, Platen Glass Scanning
Book2 Pages
Feeder Scanning, 2-Sided Scanning, Binding Erase, Different Size Originals
Document Size Auto Select, Book Frame Erase*2, Binding Erase*2, Different Size Originals
Book Frame Erase
Document Size Auto Select, Original Frame Erase*2, Binding Erase*2, Different Size Originals
Binding Erase
Book2 Pages, Original Frame Erase*2, Book Frame Erase*2
Document Size Manual Select, Book2 Pages, Original Frame Erase, Book Frame Erase
Auto (Color/B&W)
Full Color*2, Black & White*2
Full Color
Auto (Color/B&W)*2, Black & White*2
Black & White
Auto (Color/B&W)*2, Full Color*2
*1 Combination available when [Job Build] is set.
*2 If you select these modes in combination, the mode which is set last has priority.
Network/Memory Media
Function
Different Size Originals, Feeder Scanning*1, Scan Size (Free Size), 2-Sided Original
Feeder Scanning
Platen Glass Scanning*1, Scan Size (Custom), Book2 Pages
Scan Size (Auto)
Erase Book Frame, Erase Original Frame, OOXML (Word)*3, Searchable OOXML*3, OOXML (PowerPoint)*3, Auto Ratio
Scan Size (Standard)
Different Size Originals, Erase Binding*2, Erase Book Frame*2, Erase Original Frame*2, Book2 Pages*2, OOXML (Word)*3, Searchable OOXML*3, OOXML (PowerPoint)*3
Scan Size (Custom)
Different Size Originals, Erase Original Frame, Erase Book Frame, Erase Binding, OOXML (Word)*3, Searchable OOXML*3, OOXML (PowerPoint)*3, Feeder Scanning, Book2 Pages
Auto Ratio, Job Build, Different Size Originals, Erase Original Frame, Erase Book Frame, Erase Binding, OOXML (Word)*3, Searchable OOXML*3, OOXML (PowerPoint)*3, Platen Glass Scanning, Book2 Pages
Zoom
Resolution*4, OOXML (Word), Searchable OOXML, OOXML (PowerPoint), Compact XPS*5, Searchable PDF*5, Compact PDF*5, Scan Size (Auto), Scan Size (Free Size)
Original Type
Sharpness*6
2-Sided Original
Device Signature PDF (Visible)
Format PDF to PDF/A, Optimize PDF for Web*7, Encrypted PDF*8
Device Signature PDF (Invisible)
User Signature PDF (Visible)
User Signature PDF (Invisible)
Compact PDF
Resolution*9, Auto (Color/B&W), Black & White, Trace & Smooth PDF*10, Zoom*5
Encrypted PDF
Format PDF to PDF/A, PDF Files with a Security Policy, User Signature PDF (Invisible)*8, User Signature PDF (Visible)*8, Device Signature PDF (Invisible)*8, Device Signature PDF (Visible)*8
Searchable PDF
Zoom*5
Trace & Smooth PDF
Resolution*9, Auto (Color/B&W), Black & White, Compact PDF*10
User Signature PDF (Invisible)*7, User Signature PDF (Visible)*7, Device Signature PDF (Invisible)*7, Device Signature PDF (Visible)*7
Format PDF to PDF/A, Encrypted PDF
Format PDF to PDF/A
PDF Files with a Security Policy, Encrypted PDF, Device Signature PDF (Visible), User Signature PDF (Visible)
Compact XPS
Resolution*9, Auto (Color/B&W), Black & White, Zoom*5
OOXML (PowerPoint)
Resolution*9, Auto (Color/B&W), Black & White, Zoom, Scan Size (Custom)*3, Scan Size (Free Size)*3, Scan Size (Auto)*3, Scan Size (Standard)*3
Searchable OOXML
OOXML (Word)
JPEG
Auto (Color/B&W), Black & White, Divide into Pages*11
TIFF
Auto (Color/B&W), Auto (Color/Gray), Grayscale, Full Color
Divide into Pages
JPEG*11
Book2 Pages
Erase Binding, Erase Original Frame*12, Feeder Scanning, Scan Size (Custom), Scan Size (Free Size), Scan Size (Standard)*2, Different Size Originals, 2-Sided Original
Different Size Originals, Scan Size (Custom), Scan Size (Free Size), Scan Size (Auto), Scan Size (Standard)*2, Book2 Pages*12
Erase Book Frame
Erase Binding
Book2 Pages, Scan Size (Custom), Scan Size (Free Size), Scan Size (Standard)*2
Erase Book Frame, Erase Original Frame, Scan Size (Custom), Scan Size (Free Size), Scan Size (Standard), Platen Glass Scanning, Book2 Pages
Auto (Color/Gray)
TIFF
Auto (Color/B&W)
TIFF, JPEG, OOXML (Word), Searchable OOXML, OOXML (PowerPoint), Compact XPS, Trace & Smooth PDF, Compact PDF
Full Color
TIFF
Grayscale
TIFF
Black & White
JPEG, OOXML (Word), Searchable OOXML, OOXML (PowerPoint), Compact XPS, Trace & Smooth PDF, Compact PDF, Sharpness*6
Resolution
OOXML (Word)*9, Searchable OOXML*9, OOXML (PowerPoint)*9, Compact XPS*9, Trace & Smooth PDF*9, Compact PDF*9, Zoom*4, Sharpness*6
Sharpness*6
Black & White, Original Type (Text), Resolution
*2 Cannot be set if you select [A3+] for the scan size.
*3 The original is reduced into LTR size if you select the scan size that is larger than LTR.
*4 [Auto] for [Copy Ratio] can be set if the resolution is 300 x 300 dpi or 600 x 600 dpi.
*5 Cannot be set if you select Preset Zoom or Zoom by Percentage.
*6 The setting for [Sharpness] is invalid when all of the conditions below are met.
The color mode is Black & White
The original type is set to Text
The resolution is set to 100 x 100 dpi, 150 x 150 dpi, or 200 x 100 dpi.
*7 If you select [Optimize PDF for Web], you can set one of the followings:
Device Signature
User Signature
*8 If [Password Required to Change Permiss.] is set, you must set [Allow Changes] to [Changes but Extract Pages] in order to set digital signature settings.
*9 Combination available if the resolution is 300 x 300 dpi.
*10 The PDF (Compact) mode is set at the same time.
*11 [Divide into Pages] is set to 'On'.
*12 Cannot set the erase frame width in [Erase Original Frame].
