Top » Scan and Store » Setting the Resolution
0R9W-131
You can specify the resolution at which to scan the original. Scanning at high quality increases the file size, but ensures details are preserved in the final image.
As an example, the procedure for selecting memory media as the storage location is explained in this section.
This mode is only available for storing files the Advanced Box of another imageRUNNER ADVANCE machine on the network or memory media.
Press [Scan and Store] → [Memory Media].
Select the memory media → select the destination folder → press [Scan].
Press [Resolution] → select the desired resolution → press [OK].
If you are storing files in a mail box, the resolution is fixed to 600 dpi.
