Adjusting Density Manually
0R9W-13C
When scanning, you can adjust the density to the most appropriate level for the original.
As an example, the procedure for selecting memory media as the storage location is explained in this section.
Press [Scan and Store] → [Memory Media].
Select the memory media → select the destination folder → press [Scan].
Press [Options] → [Density].
If you selected a mail box, press [Density].
4.
press
to adjust the density for the original → Press [OK].
5.
Press [Close].
