Top » Copy » Erase Frame
Erase Frame
07SE-0L5
This mode enables you to erase shadows and lines that appear when copying various types of originals. There are three types of Erase Frame: [Erase Original Frame], [Erase Book Frame], and [Erase Binding].
Make sure to place your original on the platen glass. If you place originals with binding holes in the feeder, it may damage the originals. Place your original on the platen glass.
This mode erases the dark borders and frame lines that appear around the copy when the original is smaller than the selected paper size. You can also use this mode to create a blank border around the edge of the scanned image.
Erase Original Frame Not Selected
    Erase Original Frame Selected
Press [Copy].
Press [Options] → [Erase Frame].
Press [Erase Original Frame] → [Next].
To specify the original size, press [Change] → select the size → press [OK].
You can only set the Erase Original Frame mode for the original sizes shown on the touch panel display.
4.
Set the Erase Frame width.
If you want to set the same width for all four borders:
If you want to set the width for each border independently:
Press [-] or [+] to set the Erase Frame width.
Press [Adjust Independently].
Select the desired borders → press [-] or [+] to set their respective Erase Frame widths.
To return to the screen for setting the same amount of space for all four borders, press [Uniform Width].
5.
Press [OK] → [Close].
Erase Book Frame
This mode erases the dark border and the center and contour lines that appear when you copy facing pages in a book or bound original onto a single sheet of paper.
Erase Book Frame Not Selected
    Erase Book Frame Selected
Press [Copy].
Press [Erase Book Frame] → [Next].
You can set the Erase Book Frame mode only for the original paper sizes shown on the touch panel display.
4.
Press [Center] and [Sides] → press [-] or [+] to set their respective Erase Frame widths.
5.
Erase Binding
This mode erases the shadows that appear on copies from binding holes on originals when copying.
Erase Binding Not Selected
   Erase Binding Selected
Press [Copy].
Press [Erase Binding] → [Next].
4.
Specify the location of the binding holes → press [-] or [+] to set their respective Erase Frame width.
When you specify the location of the binding holes, assume that the original is face up.
5.
If you are using [Erase Binding], the borders you do not select are also erased by 1/8" (4 mm).
