Assigning Shortcuts
You can create shortcuts to frequently used functions in [Options]. You can also create shortcuts to [Favorite Settings]. For information on favorite settings, see "Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)." These shortcuts then appear on the Basic Features screens.
Creating Shortcuts to Settings in [Options]
Press [Copy].
Press .
Press [Register Options Shortcuts].
4.
Select the button to register.
5.
Select the [Options] mode you want to assign as a shortcut → press [OK].
If you do not want to assign an option, select [Unassigned].
6.
Press [OK].
Assigning a Shortcut to a Registered [Favorite Settings] Button
You can assign shortcuts to previously registered Favorite Settings buttons.
Settings can be recalled without displaying a confirmation screen from the Copy Basic Features screen.
Press [Copy].
Press .
4.
5.
Press [Preset Fav. Settings] → select assigned Favorite Settings → press [OK].
To use this setting, you must first register Favorite Settings. (See "Storing, Recalling, and Deleting Favorite Settings (Favorite Settings).")
6.
Press [OK].
» Copy » Assigning Shortcuts
07SE-0K1
