Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Mac) » Attaching a Cover Sheet
08KE-0YH
This section describes how to attach a cover sheet to an outgoing fax.
Select [Print] from the [File] menu of the application.
Select your fax → select [Cover Sheet].
Select an option for attaching the cover sheet from [Cover Sheet Attachment] → select a cover sheet template from [Style].
4.
If you want to specify the items to include on the cover sheet, click [Item Settings].
If you do not want to specify the items to include on the cover sheet, proceed to step 9.
5.
If you want to add an attention note, select [Insert Attention Note] → select a label.
You can also enter a customized label instead of one of the pre-defined labels.
Enter any other information in [Comment to include] as necessary.
6.
Click [Sender] → select items you want to print on the cover sheet regarding the sender → enter the information.
7.
Click [Recipient] → select items you want to print on the cover sheet regarding the destination.
The recipient information specified in the address book is automatically printed on the cover sheet.
8.
Set a logo or signature if necessary.
Click [Logo] or [Signature].
Select [Print with Logo] or [Print with Signature] to include a logo or signature on the cover sheet.
Click [Browse] → specify the magnification and position of the selected logo or signature.
Click [OK].
Only BMP (bitmap) files are supported as logo or signature data. You cannot select other file formats.
9.
If you want to see a preview of the cover sheet you have created, click [Sheet Preview].
10.
Click [Print].
The specified cover sheet is attached to the fax when it is sent.
The maximum number of recipients you can send a fax to at any one time differs depending on whether a cover sheet is attached to the fax. For details, see the online help (see "Viewing the Online Help").
The display may vary according to the operating system and system environment.
