Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Setting the Memory Lock Mode
08KE-0WR
You can set to store received fax documents in the Memory RX Inbox without printing them. You can later check the received documents in the Memory RX Inbox, and print or send them as necessary.
If you set [Fax Memory Lock] to 'On', you can specify the settings for <Fax Memory Lock> for the Memory RX Inbox as necessary. (See "Specifying the Fax/I-Fax Inbox Settings" and "Memory RX Inbox.")
To receive documents in memory, you must first set [Use Fax Memory Lock] or [Use I-Fax Memory Lock] to 'On'. (See "Specifying the Fax/I-Fax Inbox Settings.")
You cannot store received documents in memory in the cases below. These numbers may vary depending on the remaining capacity of the hard disk.
When a total of 2,000 documents or images are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 20,000 pages of documents or images are stored in the Mail Box and Fax/I-Fax Inbox
