Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Mac) » Before Sending a Fax from a Computer » Setting the Fax Options » Manually Setting the Fax Options
08KE-0Y6
If the machine is connected by unidirectional communication, you must set the fax options (such as the fax board) attached to and installed in the machine manually.
If the machine is connected by bidirectional communication, the settings for this procedure are disabled. Follow the procedure in "Verifying the Fax Information" to automatically set the options.
Open [System Preferences] → click [Print & Fax].
Select the fax you are using → click [Options & Supplies].
Click [Driver] → confirm that your fax is selected for [Print Using] → configure the options installed in the fax.
Be sure to select only those options that are actually installed in the fax.
4.
Click [OK].
