Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Delayed Send
Delayed Send
08KE-0WE
The Delayed Send mode enables you to store a send job in memory, and have it sent at a later time.
If multiple fax jobs reach their delayed send time simultaneously, documents are sent in the order indicated in the illustration below.
Press [Fax].
Specify the destination → press [Options] → [Delayed Send].
Enter the send time using - (numeric keys).
Enter the time as a four digit number including zeros.
Examples:
7:05 a.m. → 0705
11:18 p.m. → 2318
If you set a time earlier than the current time, the document will be sent at that time on the next day.
If you make a mistake when entering the send time, press (Clear) to clear your entry → enter another four digit number.
You can only cancel delayed send jobs from the Status Monitor/Cancel screen. (See "Canceling a Job Being Sent or Waiting to Be Sent.")
4.
Press [OK] → [Close].
You can reserve up to 64 jobs for delayed sending. However, the actual number of send jobs that the machine can handle may be less than 64, depending on the following conditions:
When multiple documents are being sent at the same time.
When large documents are being sent.
When a large amount of memory is being used for the Mail Box and Fax/I-Fax Inbox.
The number of delayed send jobs you can reserve may also be reduced if other jobs with no Delayed Send settings are being processed, or if there are other factors affecting the specified destinations.
Once the delayed documents are sent, the documents are automatically deleted from memory.
You can check the status, cancel, or change the destinations of documents for which a preset send time has been specified. (See "Checking and Canceling Send Jobs.")
