Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Sending with a Subaddress
08KE-0WW
If the destination fax machine is compatible with ITU-T (International Telecommunications Union-Telecommunications Sector) standard subaddresses and passwords, you can send or receive documents with increased security by attaching a subaddress and a password to all of your fax transactions.
Press [Fax].
Enter the fax number → press [Subaddress].
If you have added additional lines, press [Set Details].
For instructions on performing this operation from the Fax screen, see "Fax Basic Features Screen."
You cannot insert a pause at the beginning of a number.
If you enter a pause at the end of the number, the pause is always 10 seconds long.
You can use multiple lines in the following cases:
If the Super G3 2nd Line Fax Board is installed in addition to installing the Super G3 FAX Board, or the Super G3 3rd/4th Line Fax Board is installed in addition to installing the Super G3 2nd Line Fax Board and Super G3 FAX Board
If [No. of TX Lines] is set to two lines in [Remote Fax TX Settings] when using the Fax function with the Remote Fax Kit (See "Remote Fax TX Settings.")
Press [Subaddress] or [Password].
4.
Enter the subaddress and password using - (numeric keys), , and .
5.
Press [OK].
