Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Storing New Addresses
08KE-0UH
You can store a destination in the Local Address Book or a one-touch button to save the effort of entering that destination's address each time you send a job. This also enables you to retrieve the destination from the Local Address Book or one-touch button when specifying various settings.
Regarding the Local Address Book
The Local Address Book is a feature used for storing fax destinations. The Address Book is divided into 10 Address Lists and one-touch buttons. You can store up to 1,800 destinations, including 1,600 destinations in the Address Lists (1 to 10), and 200 destinations in one-touch buttons.
Registering a destination in the Local Address Book saves you the effort of entering that destination's address each time you send a job. By storing your own e-mail address, you can use the Job Done Notice mode.
Since each address entry is treated as a single entry, if you register a fax number in a group address, the fax number and group address entry are counted as two separate entries.
The Local Address Book data can be saved and imported using the Remote UI. (See "Loading Settings Information (Import Individually).")
If you want to manage destinations with the Manage Address Book Access Number mode, set [Manage Address Book Access Numbers] to 'On'. (See "Managing the Address Book with Access Numbers.")
If a required destination setting has not been set after registering the access number, the screen for specifying the destination settings appears again.
You can enter up to seven digits for the access number. If you enter fewer than seven digits, the machine stores the access number with leading zeros.
Example: If <321> is entered, <0000321> is stored.
You cannot store an access number with only zeros as the number, such as <0000000>. If you enter a number that begins in zeros, such as <02> or <002>, the zeros are ignored and the number is registered as <0000002>, the same as if you had simply entered <2>.
You can store destinations on the Log screen for [Send] on the Status Monitor/Cancel screen. (See "Checking and Canceling Send Jobs.")
