Only the Advanced Box administrator can register a user. The following are the default settings for the user name and password for the Advanced Box administrator. We recommend that you change both the user name and password.
User Name: Administrator
Password: password
To use [User Access Control for Advanced Box], set [Use HTTP] in [Preferences] (Settings/Registration) to 'On.' (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
To use the Remote UI, set [Remote UI] in [Management Settings] (Settings/Registration) to 'On'. (See "Remote UI.")
You can also log in by entering the URL of [User Access Control for Advanced Box] in the address bar, as indicated below. (Case sensitive.)
http://<IP address or host name of the machine>:8000/uactrl/
Password: password
Click [Log Out from User Access Control] to finish the operation. If you close the Web browser page without clicking [Log Out from User Access Control], the logout process will not be performed correctly. In this case, note that you will not be able to log in again for approximately 30 minutes.
