For instructions on entering characters, see "Entering Characters from the Touch Panel Display." If you have registered characters in [Register Characters for Page No./Watermark] in [Function Settings] (Settings/Registration), you can select the characters from the list.
The Serial Number, which appears at the bottom left of the screen when you press
If a login service has been set, the Department ID and user name of the user who is currently logged in to the machine are printed.
The watermark "CONFIDENTIAL" is printed if a login service is not set.
To print a pattern on the background of copy, select the background pattern from the Background Pattern drop-down list.
You can select [36.0 pt], [54.0 pt], or [72.0 pt] for the size of the text.
To change the print orientation for characters, press [Print Vertically].
To use white letters on a colored background, press [White Letters on Colored Bkg.].
If [Printer Driver Secure Watermark] and [Forced Secure Watermark] are set for a printer at the same time, Forced Secure Watermark is given priority.
If you want to use the Secure Watermark function for each job from the printer driver, on the [Printing Preferences] dialog box, click the [Finishing] tab → [Advanced Settings] → select [On] for [Secure Printing Function of Devices]. For more information, see the on-line help for the printer driver.
