Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark
Document Scan Lock
Adjusting the Secure Watermark Contrast
Adjusting Embedded Dots
Specifying the Document Scan Lock Operational Settings
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage
08KE-234
There are many possibilities connected to information leakage regarding documents and data handling; such as when you have left behind your original or output on the machine after you have made a copy or printed, or when a transmission error has occurred when you have tried to send your file or document.
On this machine, you can create a PDF with digital signature that verifies the data creator and that the data has not been altered.
To minimize the possibility of information leakage, this machine can be equipped with several security features, such as the Secure Watermark and Document Scan Lock modes to prevent unauthorized copying, the Limit New Destinations mode to prevent unauthorized send, and the Destination Confirmation mode to prevent transmission error.
Also, by specifying restrictions on the display of the Address Book or the Status Monitor/Cancel screen on the touch panel display of the machine, you can prevent unauthorized use of the machine or browsing by the unauthorized user.
Digital Signature
This mode displays the signature on the digital document, which indicates the source and therefore the legitimacy of the document. By using the public key encryption method, you can verify the data creator and that the data has not been altered.
The structure of a digital signature is indicated below. By comparing the encrypted data from the sender with the public key, the receiver can check the legitimacy of the sender and data. (See "Digital Signatures.")
You can create the following types of digital signature PDF on this machine.
Device Signature
User Signature
Besides the digital signature, you can create an encrypted PDF by registering a password to the PDF to prevent unauthorized browsing by a third party. (See "Encrypting PDF Files.")
Rights Management Server Settings
This machine can link with Adobe LiveCycle Rights Management to generate PDF files that have viewing and other privileges managed. For information on the settings for connecting to an Adobe LiveCycle Rights Management server, see "Setting a Rights Management Server."
For instructions on generating a PDF file using the Rights Management server, see "Applying a Policy" in Scan and Send and "Applying a Policy" in Scan and Store.
Preventing Output Information Leakage
The following modes can be set by administrator so that it is always reflected on the output by the general users.
Secure Watermark
This mode enables you to embed text, such as "CONFIDENTIAL," the date and time, or custom characters on the output so that the embedded text appears when the copies are copied. You can prevent unauthorized copying by the third party because you can distinguish between the original and copies of originals.  (See "Forced Secure Watermark/Document Scan Lock.")
Original
Copy A
(Secure Watermark Is Set)
Copy B
(Copy of Copy A)
Original
Copy C
([Print Vertically] Is Selected)
Copy D
(Copy of Copy C)
Document Scan Lock
This mode enables you to restrict (which means to lock) the scan job of the document when copying or printing.
Using the TL code, you can embed scan lock information on the background of the copies/prints. Scan lock information controls the operational condition how the machine restricts scan jobs. When the output with embedded scan lock information is scanned, the machine detects embedded information and restricts unauthorized copying and printing.
Original
Output with Embedded TL Code
(Scan Lock Information)
Jobs are restricted.
Copy/Print
Copy/Store/Print
Embed Scan Lock Information
You can also embed tracking information such as the user name, date/time, and device name for the operation job. By scanning the output, you can analyze the embedded information on the output and find out by whom, when, and with which machine the copy or print was made.
Also, you can embed Secure Watermark on the output so that the embedded text appears when the document is copied or printed. (See "Forced Secure Watermark/Document Scan Lock.")
Copy Set Numbering Extension Mode
This mode enables you to print the user name, the date and time, and custom characters in addition to the copy set number when copying/printing. By printing the copy set number and other information, you can prevent unauthorized copying by a third party. (See "Copy Set Numbering Options.")
Only Allow Encrypted Print Jobs Mode
The Encrypted Secure Print is a mode that strengthens the security by encrypting print data on a computer and decoding the encryption on the machine. This mode helps prevent the contents of your printed documents from being seen by other users and prevent leakage of confidential information. For instructions on using Secured Print and Encrypted Secure Print, see "Secure Print." For information on the optional products required to use Encrypted Secure Print, see "Optional Products Required for Each Function."
Also, you can set the machine to only receive encrypted secured print jobs from computers.
With this setting, you can prevent leaving behind or losing outputs since output is only possible when the password is entered. (See "Accepting Only Encrypted Secure Printing.")
If you are using the imagePASS, you cannot use the Encrypted Secure Print Software.
Preventing Information Leakage from Sending
You can prevent information leakage that occurs during sending such as entering a wrong destination by confirming the entry of destination or restricting new destinations/domain. (See "Restricting the Send Function" and "Setting the Address Book.")
Control Panel Display Restrictions
You can restrict the browsing and the use of the Status Monitor/Cancel screen and Address Book by specifying settings for each function. (See "Setting the Control Panel Display.")
