Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark
Document Scan Lock
Adjusting the Secure Watermark Contrast
Adjusting Embedded Dots
Specifying the Document Scan Lock Operational Settings
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Device Management » Specifying Device Information Delivery Settings » Setting the Receiving Machine
08KE-24C
If you want to restore device information to what it was before it was updated, only the data of the very last update is available to be restored.
While receiving and updating device information, the screen indicating that the settings are being updated appears. Operations on this machine cannot be performed until the update completes.
Restricting the Reception of Device Information
You can set whether to receive delivered device information from machines other than imageRUNNER ADVANCE 8205/8295/8285 machines, which have the Device Information Delivery Settings mode.
Press [Management Settings] → [Device Management] → [Device Information Delivery Settings].
Press [Restrict Receiving Device Information] for <Receiving Settings> → [On] → [OK].
If you do not want to restrict the reception of device information, press [Off].
4.
Press [OK].
Restoring Device Information
You can restore device information to what it was before it was updated. This is useful when you have accidentally updated the device information.
Press [Restore Data] for <Receiving Settings>.
4.
Select the information to restore → press [Start].
You cannot restore the settings of Workflow Composer to what they were before the device information was updated.
If you do not restore data for [Settings/Reg. Value] and [Address Book] at the same time, the settings in [URL Send Settings] for [Set Fax/I-Fax Inbox] and [Mail Box Settings] may be erased.
5.
Press [Yes].
6.
Press [OK] → [OK].
Restricting the Type of Information That Is Updated
You can set whether the machine receives and updates the delivered device information.
Press [Restrict Receiving for Each Function] for <Receiving Settings> → specify each setting → press [OK].
Press [On] for an item to set the machine to not receive and update that device information.
Before setting <Settings/Reg. Value>, <Dept. ID>, or <Address Book> to 'Off', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
4.
Press [OK].
Setting the Update Range of the Delivered Paper Information
You can set to register all received paper information or only the basic information of each paper type.
Basic information of paper includes <Name>, <Weight>, <Finish>, <Type>, <Color>, and <Adjust Creep Correction>.
If the received information of a paper type includes a value outside the setting range, the paper type may not be registered.
Press [Management Settings] → [Management Settings] → [Device Information Delivery Settings].
Press [Set Paper Information] for <Receiving Settings>
4.
Select [All] or [Basic Only] → press [OK].
[All]:
Registers all received paper information.
[Basic Only]:
Registers only the basic information of each paper type.
5.
Press [OK].
