Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark
Document Scan Lock
Adjusting the Secure Watermark Contrast
Adjusting Embedded Dots
Specifying the Document Scan Lock Operational Settings
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Device Management
Device Management
08KE-244
You can store the device information or refer/output the log for previous transmission. Also, various functions are available on this machine by connecting to external device. In addition, the administrator can set restrictions on the usage of those functions.
USB Settings
If you want to use the machine with the USB device, activate the connection settings. Also, you can set whether to use the MEAP driver when connecting the USB device. (See "Using the USB Port.")
If multiple machines are connected via the shared network, you can deliver the device information (management data) stored on the host machine to other client machines. The client machine receives and updates the device information. This enables you to easily manage multiple machines at the same time. (See "Specifying Device Information Delivery Settings.")
Report Settings
The machine stores and manages jobs such as copy/send and transmission of the device information delivery as a log. From the Report Settings, you can output the log as a report or set so that the report is automatically output. (See "Checking/Printing the Communication Log.")
Remote UI Settings
You can use SSL communication when setting and operating the machine using the Remote UI. (See "Remote UI.")
The administrator can also perform operations that cannot be performed from the control panel, using the Remote UI. The following are examples of such operations:
Restarting the machine
Specifying the URI (Uniform Resource Identifier) TX settings for the Advanced Box
Installing a CA certificate file
Managing (exporting/clearing) the audit log
Importing/exporting an Address List or Settings/Registration
Backing up/restoring Mail Box and Advanced Box data
For information on detailed Remote UI operations and the settings available with administrator privileges on the Remote UI, see "Remote UI."
