Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Logging In to the User Management Page
Registering/Editing the User Information of User Access Control for Advanced Box
Editing User Information by General Users
Authentication Log Management for the Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Specifying Authentication Method for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Advanced Box Settings
Specifying the Advanced Box Settings
Setting the Network
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark
Document Scan Lock
Adjusting the Secure Watermark Contrast
Adjusting Embedded Dots
Specifying the Document Scan Lock Operational Settings
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Advanced Box Settings » Specifying the Advanced Box Settings
08KE-22Y
This section describes the various settings for the Advanced Box such as the Open to Public settings, user authentication settings, and whether to allow users to use the Personal Space.
Setting the Advanced Box to Be Opened Externally as a WebDAV/SMB Server
You can set whether to make the Advanced Box of the machine open externally as a WebDAV server or SMB server on the network. Also, you can set whether to manage authentication for users of the Advanced Box which is opened externally. If authentication management is used, only users registered in [User Access Control for Advanced Box] can use the Advanced Box. (See "User Access Control for Advanced Box.")
Press [Function Settings] → [Store/Access Files] → [Advanced Box Settings].
Press [Open to Public] → select the type of server → press [OK].
[By WebDAV]:
The Advanced Box is opened externally as a WebDAV server.
[By SMB]:
The Advanced Box is opened externally as an SMB server.
Select [Off] if you do not want to open the Advanced Box externally.
If the imagePASS is attached to the machine, you cannot open the Advanced Box of the machine externally as an SMB server. Set to open as a WebDAV server on the network.
The Advanced Box cannot be opened externally as a WebDAV server and SMB server at the same time.
To open the Advanced Box externally by SMB, it is necessary to set [Use SMB Server] to 'On' in [Preferences] (Settings/Registration). (See "SMB and WINS Settings.")
To open the Advanced Box externally by WebDAV, it is necessary to set [Use WebDAV Server] to 'On' in [Preferences] (Settings/Registration). (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
4.
Press [Authentication Management] → set authentication management for the Advanced Box to be opened externally.
If you set the Advanced Box to be opened externally as an SMB server and use authentication management:
If you set the Advanced Box to be opened externally as a WebDAV server and use authentication management:
If you do not use authentication management:
For more information on authentication management, see "User Access Control for Advanced Box."
Press [On].
To use authentication management, it is necessary to set <Use SMB Authentication> in [SMB Auth. Settings] in [Preferences] (Settings/Registration) to 'On', and set the authentication type. (See "SMB and WINS Settings.")
Press [On] → [OK].
Press [WebDAV Server Settings] → [Basic].
To use authentication management, it is necessary to set the authentication type (Basic) in [WebDAV Server Settings].
Set whether to use SSL for the Advanced Box that is opened externally by WebDAV.
<Use SSL>:
[On]:
SSL communication is used.
[Off]:
SSL communication is not used.
To set <Use SSL> to 'On', it is necessary to first set the key pair and server certificate (see "Key Pair and Server Certificate Settings for Encrypted SSL Communication") and then set the key as the default key (see "Setting the Key Pair Used With SSL Encrypted Communications").
Press [Off].
5.
Press [OK].
Changes are only effective after you restart the machine (the main power switch is turned OFF, and then back ON). For instruction on restarting (turning the main power switch OFF and then ON) the machine, see "Before You Start Using This Machine."
Allowing to Create Personal Spaces
You can set whether to allow personal spaces to be created in the Advanced Box.
Press [Allow to Create Personal Space] → [On] → [OK].
If you do not want to allow personal spaces to be created, press [Off].
4.
Press [Authentication Management] → [On] → [OK].
If you want to allow personal spaces to be created, make sure you use authentication management.
Deleting All Personal Spaces/Initializing the Shared Space
You can delete all personal spaces in the Advanced Box and delete all folders and files stored in the shared space of the Advanced Box.
Delete data stored in the Advanced Box.
To delete all personal spaces:
To delete all folders and files stored in the shared space:
Press [Delete All Personal Spaces].
To select and delete a personal space that a user has created, use the Remote UI. For more information, see "Specifying the Advanced Box Settings."
If the Advanced Box is opened externally as an SMB or WebDAV server, the Advanced Box administrator can delete the folders and files created by general users by directly connecting to the Advanced Box from Windows Explorer on a computer.
Press [Initialize Shared Space].
To select and delete a folder inside the shared space, use the Remote UI. For more information, see "Specifying the Advanced Box Settings."
4.
Press [Yes].
Prohibiting Writing from External Users
For users that accessed the machine via a computer or another imageRUNNER ADVANCE series machine, you can set whether to prohibit those users from creating a folder or storing a file in the Advanced Box opened externally.
Press [Prohibit Writing from External] → [On] → [OK].
Select [Off] if you want to allow external users to create folders and store files.
To send to the Advanced Box of a machine from the same machine, it is recommended that you specify a loopback address (an address that indicates the machine on a network). You can store files sent from a loopback address even if [Prohibit Writing from External] is set to 'On'. For instructions on registering an Advanced Box folder as a destination in the Address Book, see "Registering an Advanced Box Address."
Even if [Prohibit Writing from External] is set to 'On' for an Advanced Box that is opened externally, the Advanced Box administrator can perform the following operations:
Operate folders/edit files by directly connecting to the Advanced Box from Windows Explorer on a computer.
Operate folders/edit files from [Network] in [Scan and Store] or [Access Stored Files] on the touch panel display.
Setting the File Formats Allowed for Storing
You can set the file formats allowed for storing in the Advanced Box.
Press [File Formats Allowed for Storing] → set the file formats allowed for storing → press [OK].
Details of each item are shown below:
[Dev. Supt. Formats]:
You can store files in pdf, jpg, jpe, jpeg, tif, tiff, and xps format.
[Comm. Office Formats]:
In addition to the file formats for [Dev. Supt. Formats], you can store files in doc, docm, rtf, xls, xlsx, xlsm, csv, ppt, pptm, txt, iwd, iwt, iws, or lnk format.
[All]:
There are no restrictions on the file formats for storing in the Advanced Box. In addition to the file formats for [Dev. Supt. Formats] and [Comm. Office Formats], you can store files in various formats.
Saving Operation Logs for the Advanced Box
If you have operation logs performed to the Advanced Box, you can check and trace the recorded user operations.
When this function is set to 'on', you can create operation logs for the Advanced Box. You can export/import the logs stored in the machine with the Remote UI.
For more information on the method for managing operation logs for the Advanced Box, see "Audit Log Management."
Press [Save Operation Log] → [On] → [OK].
If you do not want to save operation logs for the Advanced Box, press [Off].
