Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Setting Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Before Sending a Fax from a Computer » Installation
Installation
0C1Y-1Y4
From the menu screen of the FAX Driver Software CD-ROM, you can begin installing the fax driver, or display the "Fax Driver Installation Guide."
CD-ROM Menu:
1
[Manuals]
Click this button first to view the Fax Driver Installation Guide. You cannot view the Fax Driver Installation Guide after installation has started.
2
[Installation]
Click this button to install the fax driver.
If you are using Windows 8/Server 2012, move the installer to the desktop before installing or uninstalling.
If the CD-ROM menu is not displayed, perform the following procedure.
Windows 8/Server 2012:
If "Tap to choose what happens with this disc." is displayed: Tap (or click) this message and tap (or click) [Run MInst.exe].
If Windows Explorer is displayed: Double-click [MInst.exe].
If nothing is displayed: Click the file explorer on the desktop and double-click the CD icon in [Computer].
Windows Vista/Server 2008/7:
If the [AutoPlay] dialog box appears, click [Run MInst.exe].
If Windows Explorer opens, double-click the [MInst.exe] icon.
If nothing happens, on the [] (Start) menu, click [Computer] → double-click the CD-ROM drive icon.
Windows XP/Server 2003:
Double-click the CD-ROM icon in [My Computer] → double-click [MInst.exe].
If there is no [MInst.exe] file, double-click [Setup.exe] in the appropriate folder.
