You can specify the scan size. You can also register a custom size.
Scan Size Settings
Press [Fax] → specify the desired destinations → press the scan size button.
Select the desired scan size.
If you want to select a standard scan size:
If you want to select a nonstandard scan size longer than LTR:
If you want to specify a custom scan size:
If you want to scan LTR and LGL originals at the same time:
If you want to select a registered scan size:
Press [Long Original].
If you want to scan long originals whose width is 14" (356mm) to 24 7/8" (630 mm), press [Long Original].
Press [Custom].
Press [X] or [Y] → enter a value using the numeric keys → press [OK].
* Scanning Area
The Platen Glass
Press [Auto (LTR/LGL)].
Press [Custom] → select [Registered Size 1] or [Registered Size 2] → press [OK].
Press [OK].
Registering the Scan Size
Press [Fax] → press the scan size button.
Press [Custom].
Press [Register Size] → [Registered Size 1] or [Registered Size 2].
4.
Press [X] and [Y] → enter the scan size using the numeric keys → press [OK].
5.
Press [Cancel Set.] → [Cancel].
You cannot select [Auto (LTR/LGL)] when scanning the following types of originals. Select the desired scan size.
Originals of a size other than LGL, LTR, or STMT
Highly transparent originals, such as transparencies
Originals with an extremely dark background
If you send a fax in the Direct Sending or Manual Sending mode and place your originals in the feeder, the Scan Size setting that you specify will not be used.
Take note of the following when you set [Custom]:
Place your originals on the platen glass.
If you place your original in the feeder and set [Direct Send], you cannot perform two-sided scanning. Scan each side of the original separately.
Sent images are not rotated.
Take note of the following when you set [Long Original]:
Place your originals in the feeder.
You cannot use both [Auto (LTR/LGL)] and [Erase Frame] at the same time.
If you are sending faxes and there are no sizes on the screen matching the size of the original, select the size whose width (Y) matched the width of the original. Even if the length (X) of the size selected on the screen is shorter than that of the original, the machine scans all the contents of the original (original of up to 24 7/8" (630 mm) in length) for sending.
» Fax » Sending/Receiving a Fax » Specifying/Registering Scan Sizes
0C1Y-0KR
