Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Setting Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Mac) » Faxing Fundamentals » Viewing the Online Help
0C1Y-204
You can display the online help by clicking [] in the [Print] dialog box.
The online help includes additional information about each fax function. If the e-Manual does not provide the information you need, see the online help.
Select your fax from [Printer] → select a preferences pane → click [].
Select any one of the following preferences panes:
[General Settings] preferences pane
[Special Features] preferences pane
[Cover Sheet] preferences pane
The online help is displayed.
For details about how to display the [Print] dialog box, see "Faxing."
The screen may differ according to the operating system, as well as the type and version of the fax driver.
