Size of Received Document
Paper Size Priority
11" x 17"
LTR* → LGL* → STMT x 2
LGL
LTR x 2 → STMT x 2
LTR
LTR → LGL → STMT x 2
STMT
STMT → LTR → LGL
Received documents can be printed on the following paper sizes and paper types:
Size: LGL, LTR, or STMT
Paper Types: plain, recycled, color, or custom paper type (paper with the following settings; Paper Weight: 17 to 28 lb bond (64 to 105 g/m2), Type: Normal, Finish: Uncoated or Recycled)
You can set the machine to reduce received documents in 1% increments between 75% to 97% if the document is larger than any of the available paper sizes. (See "Reducing a Received File.")
You can set the machine to print received documents on both sides of the paper. (See "2-Sided Printing.")
