Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Setting Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Selecting a Profile for Faxing
0C1Y-1YF
You can apply registered fax settings by simply selecting an item from [Profile] list.
Select [Print] from the [File] menu of the application.
Select your fax from [Name] → click [Properties].
In Windows 8/Server 2012, if you want to send a fax from the Windows Store app, display the charm bar to the right of the screen, and tap [Devices] → the printer you are using → [Print]. When you print in this way, you can only set some of the print functions. If the message [The printer requires your attention. Go to the desktop to take care of it.] is displayed, move to the desktop and proceed to step 3.
Select a profile from the [Profiles] list according to your objective.
You can select a profile in the [Sending Settings], [Cover Sheet], or [Special] tab.
4.
Click [OK].
For information on registering a profile, see "Registering a Profile for Faxing."
Faxing methods may vary according to the application you are using. For details, see the instruction manuals provided with the application.
The display may vary according to the operating system and system environment.
