Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Setting Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Erase Frame
Erase Frame
0C1Y-0L2
This mode enables you to remove the shadows and lines that appear when scanning various types of originals. There are three types of Erase Frame: [Erase Original Frame], [Erase Book Frame], and [Erase Binding].
Make sure to place your original on the platen glass. If you place originals with binding holes in the feeder, it may damage the originals. Place your original on the platen glass.
This mode deletes the dark borders and frame lines that appear around the scanned image if the original is smaller than the specified paper size. You can also use this mode to create a blank border around the edge of the scanned image.
Example: Scanning an STMT original as LTR size.
Original Frame Erase
 Not Selected
 Selected
Press [Fax].
Specify the destination → press [Options] → [Erase Frame].
Press [Erase Original Frame] → set the image orientation and position → press [Next].
To specify the original size, press [Change] → select the size → press [OK].
You can only set the Erase Original Frame mode for the original sizes shown on the touch panel display.
4.
Sets the erase frame width.
If you want to set the same width for all four borders:
If you want to set the width for each border independently:
Press [-] or [+] to set the erase frame width.
Press [Adjust Independently].
Select the desired borders → press [-] or [+] to set their respective Erase Frame widths.
To return to the screen for setting the same amount of space for all four borders, press [Uniform Width].
5.
Press [OK] → [Close].
Erase Book Frame
This mode deletes the dark borders, as well as center and contour lines that appear when you scan an original such as a magazine or a book.
Book Frame Erase
Not Selected
Book Frame Erase
Selected
Press [Fax].
Press [Erase Book Frame] → set the image orientation and position → press [Next].
You can set the Erase Book Frame mode only for the original paper sizes shown on the touch panel display.
4.
If you want to set the top, left, center, right, and bottom widths independently:
Press [Center] and [Sides] → press [-] or [+] to set their respective Erase Frame widths.
5.
Erase Binding
This mode deletes the shadows that appear on scanned images from binding holes on originals.
Binding Erase
Not Selected
Binding Erase
Selected
Press [Fax].
Press [Erase Binding] → set the image orientation and position → press [Next].
4.
Specify the location of the binding marks → press [-] or [+] to set the erase frame width.
When you specify the location of the binding holes, assume that the original is face up.
5.
If you are using [Erase Binding], the borders you do not select are also erased by 1/8" (4 mm).
You cannot use both [Auto (LTR/LGL)] and [Erase Frame] at the same time.
