Category
Top » Copy » Viewing Copy Settings
Category Top
Basic Copy Operations
Attention (Combination of Copy Settings)
Checking and Canceling Copy Jobs/Checking Copy Job History
Selecting Copy Papers
Adjusting the Density
Density Adjustment
Background
Selecting the Document Type
2-Sided Copying
Copying 1-Sided Document to 2 Sides
Copying 2-Sided Document to 2 Sides
Copying 2-Sided Document to 1 Side
Enlarging/Reducing Copies
Copying Multiple Documents onto One Sheet (N on 1)
2 on 1/4 on 1
Copying an ID Card
Attention (ID Card Copy)
Copying by Saving Paper
Collating Copies
Erasing Dark Borders and Frame Lines (Frame Erase)
Emphasizing the Outline of the Image (Sharpness)
Registering and Using Combination of Copy Settings (Mode Memory)
Registering Mode Memory
Deleting Mode Memory
Calling and Copying Mode Memory
Changing the Default Settings
Collapse all|Expand all
07K4-06H
You can confirm the settings of copy function which have been changed from the default setting.
1
Press [] (View Settings).
The current settings in the machine are displayed.
If you have not changed the default settings, the message <No settings have been changed.> is displayed.
2
Check your settings.
You can change those settings.
Select items and press [OK] to display a setting screen for those items, where you can change those settings.
3
Press [] (Back) to return to the standby display.
