Erasing Dark Borders and Frame Lines (Frame Erase)
07K4-067
If the document is smaller than the copy paper size, you can erase dark borders and frame lines that appear around the copy paper. Also, you can provide a constant width of margin (white background) around the copy paper.
1
Place your document.
2
Press [
3
Select <Erase Frame> using [
] or [
] and press [OK].
4
Select <On> using [
] or [
] and press [OK].
5
Select the frame width to be erased (1/16" to 1 15/16" (1 to 50 mm)) using [
] or [
] and press [OK].
You can also enter the frame width to be erased using the numeric keys.
6
Select the size of the original document using [
] or [
] and press [OK].
7
Press [
] (Start).
