Up to 50 documents can be loaded into the feeder.
Copy Settings
When you combine multiple settings for use, see "Attention (Combination of Copy Settings)."
The settings specified here are effective only for the current operation. To make the settings effective for all the copy operations, see "Changing the Default Settings."
Register your frequently used settings into the Mode Memory. It is useful. See "Registering and Using Combination of Copy Settings (Mode Memory)."
Press [
] (Clear) to cancel the entered quantity. |
] (Start).
When <Incorrect Size/Setting> appearsChange the <Paper Settings> menu or load the paper size specified in the <Paper Settings> menu.
When the message <Memory is full. Scanning canceled. Print?> appearsPrint the pages successfully scanned or cancel the job.
To copy a document without margins
The image may be partially cut off on the output. See the following section in "Specifications" for more information.
