Category
Top » Copy » Checking and Canceling Copy Jobs/Checking Copy Job History » Checking Copy Job History
Category Top
Basic Copy Operations
Attention (Combination of Copy Settings)
Selecting Copy Papers
Adjusting the Density
Density Adjustment
Background
Selecting the Document Type
2-Sided Copying
Copying 1-Sided Document to 2 Sides
Copying 2-Sided Document to 2 Sides
Copying 2-Sided Document to 1 Side
Enlarging/Reducing Copies
Copying Multiple Documents onto One Sheet (N on 1)
2 on 1/4 on 1
Copying an ID Card
Attention (ID Card Copy)
Copying by Saving Paper
Collating Copies
Erasing Dark Borders and Frame Lines (Frame Erase)
Emphasizing the Outline of the Image (Sharpness)
Registering and Using Combination of Copy Settings (Mode Memory)
Registering Mode Memory
Deleting Mode Memory
Calling and Copying Mode Memory
Changing the Default Settings
Viewing Copy Settings
Collapse all|Expand all
07K4-05H
1
Press [] (Status Monitor/Cancel).
2
Select <Copy/Print Job> using [] or [] and press [OK].
3
Select <Copy Job History> using [] or [] and press [OK].
4
Select a job that you want to check using [] or [] and press [OK].
5
Select an item that you want to check using [] or [] and press [OK].
6
Check the details.
7
Press [] (Status Monitor/Cancel) to close the screen.
