Category
Top » Copy » Selecting Copy Papers
Category Top
Basic Copy Operations
Attention (Combination of Copy Settings)
Checking and Canceling Copy Jobs/Checking Copy Job History
Adjusting the Density
Density Adjustment
Background
Selecting the Document Type
2-Sided Copying
Copying 1-Sided Document to 2 Sides
Copying 2-Sided Document to 2 Sides
Copying 2-Sided Document to 1 Side
Enlarging/Reducing Copies
Copying Multiple Documents onto One Sheet (N on 1)
2 on 1/4 on 1
Copying an ID Card
Attention (ID Card Copy)
Copying by Saving Paper
Collating Copies
Erasing Dark Borders and Frame Lines (Frame Erase)
Emphasizing the Outline of the Image (Sharpness)
Registering and Using Combination of Copy Settings (Mode Memory)
Registering Mode Memory
Deleting Mode Memory
Calling and Copying Mode Memory
Changing the Default Settings
Viewing Copy Settings
Collapse all|Expand all
07K4-05J
See "Attention (Changing Print Settings)" before you start copying.
You can select the paper drawer manually.
Drawer 1
Drawer 2
Multi-purpose tray
You need to specify the paper size and type to be loaded beforehand.
1
Place your document.
2
Press [].
3
Press [] (Select Paper/Settings).
You can display the setting screen also by selecting <Paper> in the copy mode screen.
4
Select the paper drawer using [] or [] and press [OK].
5
Press [] (Start).
