Category
Top » Copy » Changing the Default Settings
Category Top
Basic Copy Operations
Attention (Combination of Copy Settings)
Checking and Canceling Copy Jobs/Checking Copy Job History
Selecting Copy Papers
Adjusting the Density
Density Adjustment
Background
Selecting the Document Type
2-Sided Copying
Copying 1-Sided Document to 2 Sides
Copying 2-Sided Document to 2 Sides
Copying 2-Sided Document to 1 Side
Enlarging/Reducing Copies
Copying Multiple Documents onto One Sheet (N on 1)
2 on 1/4 on 1
Copying an ID Card
Attention (ID Card Copy)
Copying by Saving Paper
Collating Copies
Erasing Dark Borders and Frame Lines (Frame Erase)
Emphasizing the Outline of the Image (Sharpness)
Registering and Using Combination of Copy Settings (Mode Memory)
Registering Mode Memory
Deleting Mode Memory
Calling and Copying Mode Memory
Viewing Copy Settings
Collapse all|Expand all
07K4-06F
See "Attention (Combination of Copy Settings)" before you start configuration.
The default settings are a set of standard settings predetermined by the machine. These settings become effective when the machine is turned OFF and ON, or when [] (Reset) is pressed to revert to the default settings. You can change the following default settings based on your needs.
1
Press [] (Menu).
2
Select <Copy Settings> using [] or [] and press [OK].
3
Select <Change Defaults> using [] or [] and press [OK].
4
Select the item using [] or [] and press [OK].
For more information, see the following sections.
5
Select <Apply> using [] or [] after you have specified the setting and press [OK].
6
Press [] (Menu) to close the menu screen.
