<No. of Copies>
Nothing special.
<Density>
When <Background> is set to <Auto>, <Original Type> is changed to <Text>.
<Original Type>
If <Original Type> is set other than <Text> when <Background> is set to <Auto>, the <Auto> setting in <Background> will be cancelled.
<2-Sided>
Depending on its paper size (selected paper drawer), 2-sided copy is not available.
Depending on its paper size or paper type in the selected paper source, 2-sided copy is not available.
This feature cannot be combined with <ID Card Copy>.
<Copy Ratio>
When you want to copy documents in a reduction ratio different from its default value for <4 on 1>/<2 on 1>, secify the <Copy Ratio> later.
<Copy Ratio> is fixed at 100 % for <ID Card Copy>.
The frame width specified at <Erase Frame> increases/decreases according to the <Copy Ratio> setting.
<Paper>
Depending on its document size (selected paper source), 2-sided copy is not available.
<4 on 1>/<2 on 1>
If you want to copy a document in a copy ratio different from its default reduction ratio, specify the <Copy Ratio> later.
This feature cannot be combined with <Erase Frame>.
<ID Card Copy>
<Copy Ratio> is fixed at 100%.
This feature cannot be combined with either 2-Sided Copy or <Erase Frame>.
<Collate>
Nothing special.
<Erase Frame>
This feature cannot be combined with N on 1 (<4 on 1> / <2 on 1>, <ID Card Copy>).
The specified erase frame width increases/decreases according to the <Copy Ratio> setting.
<Sharpness>
Nothing special.
