e-ManualTopSite mapHelp
Chapter Top
Available Functions
Overview of Login Services
SSO-H (Single Sign-On H)
System Requirements (SSO-H)
Launching and Closing SMS
Before Launching SMS (Preparation)
Setting Up HTTP Communication
Launching SMS (Log in)
Attention (Launching SMS (Log in))
Closing SMS (Logging Out)
MEAP Application Settings
Installing MEAP Applications
Attention (Installing MEAP Applications)
Uninstalling MEAP Applications
Starting/Stopping MEAP Applications
Starting MEAP Applications
Checking the Details of MEAP Applications
MEAP Application License Settings
Adding License Files
Disabling License Files
Downloading Disabled License Files
Deleting Disabled License Files
Setting Authentication Information for MEAP Applications
System Settings
Changing the MEAP Applet Display Order
Login Service Selection
Uninstalling a Login Service
Setting Enhanced System Applications
Starting/Stopping Enhanced System Applications
Starting Enhanced System Applications
Installing Enhanced System Applications
Uninstalling Enhanced System Applications
Checking Information
Checking System Information
Checking Application Information
Checking License Files
Changing the SMS Password
Deleting the MEAP Application Setting Information
Managing MEAP Application Log Data
Downloading Log Data
Deleting Log Data
Setting the SSO-H Function
Before Logging In to SSO-H
Logging In to SSO-H
Menu for Administrators
Setting the SSO-H Configuration
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting (SSO-H)
Other Trouble
List of Error Messages (MEAP)
Errors Relating to the [Login] Page
Errors Relating to the [MEAP Application Management] Page
Errors Relating to the [Install MEAP Application] Page
Errors Relating to the [Authentication Information Settings] Page
Errors Relating to the [License Management] Page
Errors Relating to the [Enhanced System Application Management] Page
Errors Relating to the [Check License] and [Change Password] Pages
Errors Relating to the [MEAP Application Setting Information Management] Page
Errors Relating to the [MEAP Application Log Management] Page
Other Errors
Top » MEAP » Overview of Login Services » SSO-H (Single Sign-On H) » System Requirements (SSO-H)
07E3-0U5
SSO-H operates with the following system environments:
To use Active Directory Authentication, you must match the current time on the server in which Active Directory is running with the machine (and the computer to log in with).
When using Server Authentication, make sure you register a Server Authentication administrator. If you do not register a Server Authentication administrator, some settings and management functions may not be available, depending on the application. The registration method differs depending on your system environment.
The user that belongs to the "Canon Peripheral Admins" group on Active Directory is the administrator for Server Authentication by default. (You can also set other groups to the administrator.) Follow the instructions in the manual for Active Directory to create the "Canon Peripheral Admins" group, and then register a Server Authentication administrator.
If the default password is being used, the screen for changing the password is automatically displayed for security purposes. Change the password. (See "Registering/Editing User Data for Local Device Authentication.")
Windows Server Used for Active Directory Authentication (Domain Controller)
A windows server in which Active Directory is installed and a DNS server for name resolution are necessary to use Active Directory Authentication with SSO-H.
Windows Server to Install Active Directory (Domain Controller)
Software
Operating system:
Windows Server 2003 SP2*
Windows Server 2003 R2 SP2*
Windows Server 2008 SP2*
Windows Server 2008 R2
* 64 bit version for the operating system is not supported.
This version of SSO-H is compatible with both 128-bit AES (Advanced Encryption Standard) and DES (Data Encryption Standard) as the Kerberos encryption type to be used when performing Domain Authentication. The encryption type automatically switches according to the Active Directory settings. AES is used in an environment that supports both encryption types.
If you use Windows Server 2003 SP2/R2 SP2 for the Active Directory, only the IPv4 communication protocol is supported (IPv6 cannot be used).
Server Ports Used
The following server ports are used when using Active Directory Authentication with SSO-H:
Port Number
Application
53
Communication with the DNS server
88
Domain Authentication with the KDC (Key Distribution Center)
389
LDAP communications with the directory service (Default is 389, but it can be changed to a user-defined port in the LDAP service properties.)
System Requirements for Administrators and General Users
The following system environments are necessary for administrators and general users to use SSO-H via a web browser.
System Requirements
Operating System
Web Browser
Java Runtime Environment
Windows XP Professional SP3
Internet Explorer 7
Internet Explorer 8
Java Runtime Environment 1.5 or later*
Windows Vista SP2
Internet Explorer 7
Internet Explorer 8
Internet Explorer 9
Windows 7 SP1
Internet Explorer 8
Internet Explorer 9
Internet Explorer 7
Internet Explorer 8
Internet Explorer 7
Internet Explorer 8
Internet Explorer 9
Windows Server 2008 R2 SP1
Internet Explorer 8
Internet Explorer 9
Mac OS X v 10.5
Safari 4.0.5
Safari 5.0.5
Java 2 Platform Standard Edition 5.0
Mac OS X v 10.6
Safari 4.0.5
Safari 5.0.5
Safari 5.1
Mac OS X Lion
Safari 5.1
* If you use Java Runtime Environment 1.6 with Internet Explorer 9, use Java Runtime Environment 1.6.0_24 or later.
System Requirements (When Using IPv6 Communications)
Operating System
Web Browser
Internet Explorer 7
Internet Explorer 8
Windows Vista SP2
Internet Explorer 7
Internet Explorer 8
Internet Explorer 9
Windows 7 SP1
Internet Explorer 8
Internet Explorer 9
Internet Explorer 7
Internet Explorer 8
Internet Explorer 7
Internet Explorer 8
Internet Explorer 9
Internet Explorer 8
Internet Explorer 9
For information on obtaining the Java Runtime Environment or Java 2 Platform Standard Edition, see the Oracle Web site.
You must use the user logon name (pre-Windows 2000) registered in Active Directory in order to enter a user name for Domain Authentication. You can use only alphanumeric characters for Domain Authentication.
You cannot use symbols (\ / : * ? l <> [ ] ; , = + . "), or spaces. You can log in only if you use valid characters.
User names and passwords are registered in a database in the machine.
When using the Local Device Authentication system, you can use only alphanumeric characters for the user name.
Port number is a default value. If you change the settings, the port number is different. (See "Before Logging In to SSO-H.")
