e-ManualTopSite mapHelp
Chapter Top
Available Functions
Overview of Login Services
SSO-H (Single Sign-On H)
System Requirements (SSO-H)
Launching and Closing SMS
Before Launching SMS (Preparation)
Setting Up HTTP Communication
Launching SMS (Log in)
Attention (Launching SMS (Log in))
Closing SMS (Logging Out)
MEAP Application Settings
Installing MEAP Applications
Attention (Installing MEAP Applications)
Uninstalling MEAP Applications
Starting/Stopping MEAP Applications
Starting MEAP Applications
Checking the Details of MEAP Applications
MEAP Application License Settings
Adding License Files
Disabling License Files
Downloading Disabled License Files
Deleting Disabled License Files
Setting Authentication Information for MEAP Applications
System Settings
Changing the MEAP Applet Display Order
Login Service Selection
Uninstalling a Login Service
Setting Enhanced System Applications
Starting/Stopping Enhanced System Applications
Starting Enhanced System Applications
Installing Enhanced System Applications
Uninstalling Enhanced System Applications
Checking Information
Checking System Information
Checking Application Information
Checking License Files
Changing the SMS Password
Deleting the MEAP Application Setting Information
Managing MEAP Application Log Data
Downloading Log Data
Deleting Log Data
Setting the SSO-H Function
Before Logging In to SSO-H
Logging In to SSO-H
Menu for Administrators
Setting the SSO-H Configuration
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting (SSO-H)
Other Trouble
List of Error Messages (MEAP)
Errors Relating to the [Login] Page
Errors Relating to the [MEAP Application Management] Page
Errors Relating to the [Install MEAP Application] Page
Errors Relating to the [Authentication Information Settings] Page
Errors Relating to the [License Management] Page
Errors Relating to the [Enhanced System Application Management] Page
Errors Relating to the [Check License] and [Change Password] Pages
Errors Relating to the [MEAP Application Setting Information Management] Page
Errors Relating to the [MEAP Application Log Management] Page
Other Errors
Top » MEAP » List of Error Messages (MEAP) » Errors Relating to the [License Management] Page
07E3-0J1
The specified file does not exist or the file path is incorrect. Try to specify the path again.
Problem
The file does not exist on the specified path or the file path is incorrect.
Action
Specify the file path correctly.
The contents of the file for the license to install are incorrect or information is missing. Check the file.
Problem
Either the content of the file is not correct or information is missing.
Action
This license file cannot be installed. Contact the application developer.
Cannot install this license because the specified license does not correspond to this application. Try to specify a path for the license file again.
Problem
The specified license file does not correspond to the application, so they cannot be installed.
Action
Specify the license file that corresponds to the application.
Check to make sure that the manifest file listed inside the license file is correct.
Cannot install this license because the number of license file ID logs that can be saved has exceeded the limit. Contact your service representative.
Problem
The license file cannot be installed because the number of license file ID information logs contained in the license file exceeds the number that can be saved.
Action
Contact your local authorized Canon dealer or sales representatives.
Cannot install because a used license file is specified. Try to specify the file again.
Problem
According to the specifications, a license file which is already installed cannot be installed again. The specified license file has already been installed.
Action
Since the specified license file cannot be installed, specify another file.
The specified license does not match this device. Specify an installable license.
Problem
License files contain lists of printers in which they can be installed. The specified license file cannot be installed in this printer.
Action
Specify a license file that can be installed in this printer.
Could not cancel installation. Installation has been successfully completed.
Problem
The [Cancel] button was pressed when the installation operation could not be cancelled.
Action
Disable the license file, download it from the [License Management] page, and then uninstall it.
Cannot install the license because another application is being installed, or the firmware being updated.
Please wait a moment and then try again.
Problem
Either it is installed in another application outside of SMS, or the license file cannot be installed because the firmware has been updated.
Action
Wait until the processing stops before installing the license file.
Cannot disable the license file because this application has been started. Disable the license file after stopping the application.
Problem
You cannot disable a license if the corresponding application is still running.
Action
Stop the application that corresponds to the license before disabling the license.
Error: <Error Details>
Problem
An error has occurred for some reason. See <Error Details> for details.
Action
If the solutions given in <Error Details> are unclear, contact the application developer.
