e-ManualTopSite mapHelp
Chapter Top
Available Functions
Overview of Login Services
SSO-H (Single Sign-On H)
System Requirements (SSO-H)
Launching and Closing SMS
Before Launching SMS (Preparation)
Setting Up HTTP Communication
Launching SMS (Log in)
Attention (Launching SMS (Log in))
Closing SMS (Logging Out)
MEAP Application Settings
Installing MEAP Applications
Attention (Installing MEAP Applications)
Uninstalling MEAP Applications
Starting/Stopping MEAP Applications
Starting MEAP Applications
Checking the Details of MEAP Applications
MEAP Application License Settings
Adding License Files
Disabling License Files
Downloading Disabled License Files
Deleting Disabled License Files
Setting Authentication Information for MEAP Applications
System Settings
Changing the MEAP Applet Display Order
Login Service Selection
Uninstalling a Login Service
Setting Enhanced System Applications
Starting/Stopping Enhanced System Applications
Starting Enhanced System Applications
Installing Enhanced System Applications
Uninstalling Enhanced System Applications
Checking Information
Checking System Information
Checking Application Information
Checking License Files
Changing the SMS Password
Deleting the MEAP Application Setting Information
Managing MEAP Application Log Data
Downloading Log Data
Deleting Log Data
Setting the SSO-H Function
Before Logging In to SSO-H
Logging In to SSO-H
Menu for Administrators
Setting the SSO-H Configuration
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting (SSO-H)
Other Trouble
List of Error Messages (MEAP)
Errors Relating to the [Login] Page
Errors Relating to the [MEAP Application Management] Page
Errors Relating to the [Install MEAP Application] Page
Errors Relating to the [Authentication Information Settings] Page
Errors Relating to the [License Management] Page
Errors Relating to the [Enhanced System Application Management] Page
Errors Relating to the [Check License] and [Change Password] Pages
Errors Relating to the [MEAP Application Setting Information Management] Page
Errors Relating to the [MEAP Application Log Management] Page
Other Errors
Top » MEAP » Setting the SSO-H Function » Before Logging In to SSO-H
08X4-0XE
SSO-H is an authentication system that runs on the machine. It is necessary to specify the following settings in the machine to use SSO-H for authentication.
Installing SSO-H
Obtaining a license file
In order to install SSO-H, a valid license file is required.
Obtain a valid license file from License Management System (http://www.canon.com/lms/license/).
In order to obtain a license file, a license access number in your package of AMS KIT and a device serial number (the number displayed on the upper left of the SMS screen) are required.
Installation of SSO-H
For SSO-H installation procedure, see "Installing Enhanced System Applications."
The following files are required for installation.
File to be selected with [Enhanced System Application File Path]
The following file stored in the "AMS for SFP Software/Manual CD-ROM":
SSOHforSFP_xxx.jar (xxx varying with the version)
File to be selected with [License File Path]
License file obtained in License Management System
Specifying the Various Settings
Network Settings
Confirm the machine's IP address. For more information, see "[Setup] Menu ([Network] Options)."
Date and Time Settings
When using Active Directory Authentication with SSO-H, it is necessary to synchronize the date and time settings of the authentication server and machine. Set the date and time of the machine in [Date/Time Settings] to the same date and time set on the authentication server. For more information, see "[Setup] Menu ([Control Menu] Options)." You can also specify daylight saving settings to automatically advance the standard time of the machine forward by one hour for a certain period each year.
DNS Settings (Active Directory Authentication)
For Active Directory Authentication, the machine uses a DNS server. If using Active Directory Authentication, specify the network settings. For more information, see "[Setup] Menu ([Network] Options)."
The DNS server that manages the domain name registered in the machine requires the following:
The domain name of the Active Directory server used for authentication (the IP address of the domain controller) must be able to be retrieved.
The DNS server must support SRV records.
The following settings are required if the port number used for LDAP on the Active Directory side is changed.
Information for the LDAP service of Active Directory must be registered as an SRV record as follows:
Service:
'_ldap'
Protocol:
'_tcp'
Port number:
The port number used by the LDAP service of the Active Directory domain (zone)
Host offering this service:
Host name of the domain controller that is actually providing the LDAP service of the Active Directory domain (zone)
Department ID Management Settings
Department ID Management must be disabled before using SSO-H. For instructions on disabling Department ID Management, see "Specifying an ID for Each Department ."
Language Settings
Specify the same language settings for Active Directory and the machine.
If the date and time settings of the authentication server and machine are not synchronized, a login error will occur when using Active Directory Authentication.
The allowed difference in times can be changed using the settings of Active Directory. However, if more than '5' minutes is specified, the allowed difference will not be changed.
If Department ID Management is enabled, a warning message will be displayed on the login screen.
