Setting Authentication Information for MEAP Applications
When processing jobs from applications that do not require operation from the printer, you must first set the authentication information.
1
Start SMS (Service Management Service).
2
Click [MEAP Application Management].
3
Click the name of the application for which to set authentication information.
4
Click [Authentication Information Settings].
5
Enter the authentication information.
If you use department ID management
Enter the department ID and password in the fields marked [Department ID] and [PIN].
If you do not use department ID management
Enter an arbitrary ID and password in the fields marked [Department ID] and [PIN].
6
Click [Update].
Authentication information is set.
When cancelling authentication information
Click [Delete].
» MEAP » MEAP Application Settings » Setting Authentication Information for MEAP Applications
08X4-0WH
