Only the System Administrator (Administrator) can edit the user data.
Only the Local Device Authentication administrator can register/edit user data on the [User Management] page. General users can only change their own password.
It is recommended that you export the registered/edited user data to make a back up copy.
Item
Setting Content
Setting Conditions
Default Setting
User Name
Set user name when logging in.
Must be from 1 to 32 characters. You cannot include spaces or the following symbols (\ / : * ? l < > [ ] ; , = + @ ")
Case sensitive.
You cannot register a user name that has already been registered.
Administrator
Password
Set password when logging in.
You can leave this blank or enter up to 32 characters.
Case sensitive.
password
Confirm
Enter the password you entered for [Password].
Case sensitive.
password
Department ID
Set Department ID to be used when printing with the machine.
Must be from 1 to 7 digits (this can be omitted if Department ID Management is disabled).
If the number you enter does not contain enough digits, zeros are added to the front of the number.
0000000
PIN
Set PIN corresponding to Department ID.
You can leave this blank or enter up to 7 digits. (this can be omitted if Department ID Management is disabled).
0000000
Confirm
Enter the PIN you entered for [PIN].
0000000
Displayed As
Set the user display name (for example, user's full name, user's department name, etc.)
Administrator
E-Mail Address
Set the user's e-mail address.
You can leave this blank or enter up to 256 ASCII characters.
The format of e-mail addresses is not checked.
Blank
Select Role to Set
Set the user role (privileges).
You can set the following user roles (privileges):
Administrator
All operations are possible. General User
Operations other than those of the Device Management and Network Management are possible. |
Administrator
If you select [Administrator] for [Select Role to Set], the user name and password can be used when you log in using Local Device Authentication.
To enable Department ID Management, it is necessary to register the Department ID and PIN as the user information of the administrator for Local Device Authentication beforehand.
If Department ID Management is enabled, the registered information for Local Device Authentication and the registered user data and PIN in the machine's Department ID Management have to match. If the Department ID and PIN have been changed due to the delivery of device information, make sure to change the Local Device Authentication settings accordingly.
Multiple users can share the same Department ID.
Multiple users can be registered as a System Administrator (Administrator).
Enter the same string for [Password]/[PIN] and [Confirm]. If you enter a different string for [Password]/[PIN] and [Confirm], a message prompting you to re-enter the passwords/PIN appears.
, or page numbers to display other pages.
, or page numbers to display other pages.|
To select all registered applications, click [Select All].
[File Format]
Specify the file format for importing.
[SDL Format]
Import the user data created in the file format used for SDL and the Local Device Authentication of SSO-H. (File extension: "ldif")
[NetSpot Accountant 3.x Format]
Import the user data created in NetSpot Accountant 3.x Format. (File extension: "csv")
[NetSpot Accountant 4.x Format]
Import the user data created in NetSpot Accountant 4.x/iW Accounting Manager Format. (File extension: "csv")
[Encoding]
Specify the character code for importing.
Windows Japanese (CP932)
Import the file written in Windows Japanese Format. Windows Japanese is a character code for Japanese.
Windows Latin-1 (CP1252)
Import files written in Windows Latin Format. Windows Latin is a character code for European languages.
[User Name Type]
Select the type of user name used for logging in.
[User ID]
Use the user ID as the user name for logging in.
[Windows User Name]
Use User Name in Windows as the user name for logging in.
If user data with the same name is already registered, the imported user data will overwrite the old data.
[File Format]
Specify the file format for exporting.
[SDL Format]
Export the user data in the file format used for SDL and the Local Device Authentication of SSO-H. (File extension: "ldif")
Export the user data created in NetSpot Accountant 3.x Format. (File extension: "csv")
Export the user data created in NetSpot Accountant 4.x/iW Accounting Manager Format. (File extension: "csv")
[Encoding]
Specify the character code for file exporting.
Export the file written in Windows Japanese Format. Windows Japanese is a character code for Japanese.
Windows Latin-1(CP1252)
Export files written in Windows Latin Format. Windows Latin is a character code for European languages.
A maximum of 500 users can be registered.
You cannot change the user name.
If you edit user data when that user is logged in, the changes you made are validated only after that user is logged out.
If you want to change the user name, you must delete the user data, create, and register new user data.
The user data that is logged in as the System Administrator (Administrator) cannot be deleted.
Imported user data is registered or overwritten as General User.
User Type of all exported data is General User.
Click [User Name], [Department ID] (if Department ID Management is enabled), [Displayed As], [Select Role to Set], or [E-Mail Address] on the [User Management] page to change the sort order of registered user data.
An asterisk (*) is displayed on the right side of the user name on the [User Management] page for the registered System Administrator (Administrator).
