e-ManualTopSite mapHelp
Chapter Top
Available Functions
Overview of Login Services
SSO-H (Single Sign-On H)
System Requirements (SSO-H)
Launching and Closing SMS
Before Launching SMS (Preparation)
Setting Up HTTP Communication
Launching SMS (Log in)
Attention (Launching SMS (Log in))
Closing SMS (Logging Out)
MEAP Application Settings
Installing MEAP Applications
Attention (Installing MEAP Applications)
Uninstalling MEAP Applications
Starting/Stopping MEAP Applications
Starting MEAP Applications
Checking the Details of MEAP Applications
MEAP Application License Settings
Adding License Files
Disabling License Files
Downloading Disabled License Files
Deleting Disabled License Files
Setting Authentication Information for MEAP Applications
System Settings
Changing the MEAP Applet Display Order
Login Service Selection
Uninstalling a Login Service
Setting Enhanced System Applications
Starting/Stopping Enhanced System Applications
Starting Enhanced System Applications
Installing Enhanced System Applications
Uninstalling Enhanced System Applications
Checking Information
Checking System Information
Checking Application Information
Checking License Files
Changing the SMS Password
Deleting the MEAP Application Setting Information
Managing MEAP Application Log Data
Downloading Log Data
Deleting Log Data
Setting the SSO-H Function
Before Logging In to SSO-H
Logging In to SSO-H
Menu for Administrators
Setting the SSO-H Configuration
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting (SSO-H)
Other Trouble
List of Error Messages (MEAP)
Errors Relating to the [Login] Page
Errors Relating to the [MEAP Application Management] Page
Errors Relating to the [Install MEAP Application] Page
Errors Relating to the [Authentication Information Settings] Page
Errors Relating to the [License Management] Page
Errors Relating to the [Enhanced System Application Management] Page
Errors Relating to the [Check License] and [Change Password] Pages
Errors Relating to the [MEAP Application Setting Information Management] Page
Errors Relating to the [MEAP Application Log Management] Page
Other Errors
Top » MEAP » List of Error Messages (MEAP) » Errors Relating to the [Authentication Information Settings] Page
08X4-0YJ
Settings are incorrect.
Check to see if the password is incorrect.
Enter Dept. ID within 7 digits.
Check to see if the Department. ID is registered with the device.
Problem
Cannot set authentication information because either the Dept. ID entered does not exist, or the PIN was entered incorrectly.
Action
Enter a Dept. ID and PIN that are registered in the printer.
The [Department ID] is incorrect.
Enter an integer for the [Department ID].
Problem
The Dept. ID that was entered is a positive integer, but the registered Dept. ID is not a positive integer.
Action
Enter the correct Dept. ID that is registered in the device.
The [Department ID] is not entered.
Problem
The Dept. ID is blank.
Action
Specify a Dept. ID.
Could not set authentication information because an error occurred.
Problem
An error has occurred for some reason, so authentication information could not be set.
Action
Contact your local authorized Canon dealer or sales representatives.
Could not delete authentication information because an error occurred.
Problem
An error has occurred for some reason, so authentication information could not be deleted.
Action
