e-ManualTopSite mapHelp
Chapter Top
Available Functions
Overview of Login Services
SSO-H (Single Sign-On H)
System Requirements (SSO-H)
Launching and Closing SMS
Before Launching SMS (Preparation)
Setting Up HTTP Communication
Launching SMS (Log in)
Attention (Launching SMS (Log in))
Closing SMS (Logging Out)
MEAP Application Settings
Installing MEAP Applications
Attention (Installing MEAP Applications)
Uninstalling MEAP Applications
Starting/Stopping MEAP Applications
Starting MEAP Applications
Checking the Details of MEAP Applications
MEAP Application License Settings
Adding License Files
Disabling License Files
Downloading Disabled License Files
Deleting Disabled License Files
Setting Authentication Information for MEAP Applications
System Settings
Changing the MEAP Applet Display Order
Login Service Selection
Uninstalling a Login Service
Setting Enhanced System Applications
Starting/Stopping Enhanced System Applications
Starting Enhanced System Applications
Installing Enhanced System Applications
Uninstalling Enhanced System Applications
Checking Information
Checking System Information
Checking Application Information
Checking License Files
Changing the SMS Password
Deleting the MEAP Application Setting Information
Managing MEAP Application Log Data
Downloading Log Data
Deleting Log Data
Setting the SSO-H Function
Before Logging In to SSO-H
Logging In to SSO-H
Menu for Administrators
Setting the SSO-H Configuration
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting (SSO-H)
Other Trouble
List of Error Messages (MEAP)
Errors Relating to the [Login] Page
Errors Relating to the [MEAP Application Management] Page
Errors Relating to the [Install MEAP Application] Page
Errors Relating to the [Authentication Information Settings] Page
Errors Relating to the [License Management] Page
Errors Relating to the [Enhanced System Application Management] Page
Errors Relating to the [Check License] and [Change Password] Pages
Errors Relating to the [MEAP Application Setting Information Management] Page
Errors Relating to the [MEAP Application Log Management] Page
Other Errors
Top » MEAP » Setting the SSO-H Function » Troubleshooting (SSO-H) » Other Trouble
Other Trouble
08X4-0YA
This section explains the various other problems that can occur, along with possible causes and remedies.
Symptom: Cannot log in using Active Directory Authentication with a user created before Active Directory was installed.
Cause
Accounts for users that were created before Active Directory was installed are automatically generated by placing them in the 'Users' folder after installing Active Directory. However, the accounts that are generated do not manage the Active Directory Authentication keys required by SSO-H. Also, as a user logon name is not set, the Active Directory Authentication System of SSO-H cannot be used for authentication because user data cannot be retrieved, even if a key is generated.
Remedy
Follow the procedure below to change the settings.
Start the Active Directory management tool, "Active Directory Users and Computers."
Right-click the user that failed to be authenticated.
Select [Properties] from the pop-up menu that appears.
Select the [Account] tab → enter a name in [User logon name] → click [OK].
Right-click the user name you changed.
Select [Reset Password] from the pop-up menu that appears.
Enter a new password in the [Reset Password] dialog box → click [OK].
Symptom: It takes time for the application to start.
Cause 1
A host whose name cannot be resolved is set in the SRV record retrieved with automatic domain retrieval.
Remedy
Perform the following on the DNS server to enable name resolution for the specified host.
Specify forwarding settings.
Add an A record.
Specify secondary settings.
Cause 2
The DNS server set cannot be found, or communication on is not possible.
Remedy
Confirm the network settings to see that the machine can communicate with the DNS server set on the machine, and adjust them if it cannot.
Cause 3
A network delay time is set.
Remedy
Adjust the network delay time.
Symptom: It takes time to determine if a login is successful.
Cause 1
Name resolution cannot be performed for the domain name specified as the login destination.
Remedy
Confirm the network settings to see that name resolution can be performed for the domain name specified as the login destination, and adjust them if it cannot.
Cause 2
The DNS server set cannot be found, or communication is not possible.
Remedy
Cause 3
Multiple domain controllers exist for managing the specified domain. If multiple domain controllers exist for managing the specified domain when using SSO-H, it may take some time to perform authentication, as each domain controller called until one answers.
Remedy
Confirm the domain controllers, and adjust them, if necessary.
