e-ManualTopSite mapHelp
Chapter Top
Available Functions
Overview of Login Services
SSO-H (Single Sign-On H)
System Requirements (SSO-H)
Launching and Closing SMS
Before Launching SMS (Preparation)
Setting Up HTTP Communication
Launching SMS (Log in)
Attention (Launching SMS (Log in))
Closing SMS (Logging Out)
MEAP Application Settings
Installing MEAP Applications
Attention (Installing MEAP Applications)
Uninstalling MEAP Applications
Starting/Stopping MEAP Applications
Starting MEAP Applications
Checking the Details of MEAP Applications
MEAP Application License Settings
Adding License Files
Disabling License Files
Downloading Disabled License Files
Deleting Disabled License Files
Setting Authentication Information for MEAP Applications
System Settings
Changing the MEAP Applet Display Order
Login Service Selection
Uninstalling a Login Service
Setting Enhanced System Applications
Starting/Stopping Enhanced System Applications
Starting Enhanced System Applications
Installing Enhanced System Applications
Uninstalling Enhanced System Applications
Checking Information
Checking System Information
Checking Application Information
Checking License Files
Changing the SMS Password
Deleting the MEAP Application Setting Information
Managing MEAP Application Log Data
Downloading Log Data
Deleting Log Data
Setting the SSO-H Function
Before Logging In to SSO-H
Logging In to SSO-H
Menu for Administrators
Setting the SSO-H Configuration
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting (SSO-H)
Other Trouble
List of Error Messages (MEAP)
Errors Relating to the [Login] Page
Errors Relating to the [MEAP Application Management] Page
Errors Relating to the [Install MEAP Application] Page
Errors Relating to the [Authentication Information Settings] Page
Errors Relating to the [License Management] Page
Errors Relating to the [Enhanced System Application Management] Page
Errors Relating to the [Check License] and [Change Password] Pages
Errors Relating to the [MEAP Application Setting Information Management] Page
Errors Relating to the [MEAP Application Log Management] Page
Other Errors
Top » MEAP » Setting the SSO-H Function » Troubleshooting (SSO-H) » Trouble That May Occur When the Windows Server Firewall Is Set
08X4-0Y9
This section explains the various problems that may occur when a firewall is set, along with possible causes and remedies.
Symptom: Service information fails to be retrieved when automatically retrieving domain information.
Cause
Communication with the DNS server is blocked due to firewall settings.
Remedy
Unblock port 53 (the default port) for the UDP protocol and TCP protocol. The DNS server normally uses port 53 to perform communications with the UDP protocol, but as data over a certain size may be processed using the TCP protocol, unblock port 53 for both the TCP protocol and UDP protocol.
Symptom: Active Directory Authentication has failed. (The <Authentication server not operating.> error message appears.)
Cause
Active Directory Authentication is blocked due to firewall settings.
Remedy
Unblock port 88 (the default port) for the UDP protocol and TCP protocol. Active Directory Authentication normally uses port 88 to perform communications with the UDP protocol, but as data over a certain size may be processed using the TCP protocol, unblock port 88 for both the TCP protocol and UDP protocol.
Symptom: User authentication has failed.
Cause
Communication for LDAP searches is blocked due to the firewall settings.
Remedy
Unblock port 389 (the default port) for the TCP protocol. User data is retrieved from Active Directory using LDAP searches. By default, LDAP searches are performed using the TCP protocol with port 389. Therefore, unblock port 389 for the TCP protocol. (If the port number used for the TCP protocol has been changed, unblock the port number used by the TCP protocol.)
