Before loading paper, see "Important Safety Instructions."
Before loading paper, be sure to turn ON the printer once.
This may result in misfeeds.
![]() When printing from Drawer 2 or 3 (both optional)
Make sure that Drawer 1 is set before printing from Drawer 2 or 3.
If you print from Drawer 2 or 3 when Drawer 1 is not set, this will cause paper jams.
This may result in paper jams or damage to the printer.
Multiple sheets of paper may be fed at a time. In this case, fan the paper thoroughly, and then align the edges of the stack properly on a hard, flat surface.
When loading A5 paper
The orientation setting to be selected on the control panel depends on how you load paper. Select the correct setting.
For paper orientation and printing side, see "Paper Loading Orientation."
For settings displayed on the control panel, see "[Setup] Menu ([Paper Source] Options)" or "[Select Feeder] Menu."
