: Available
: Unavailable|
Paper Type
Setting for [Paper Type]*1
Paper Size
Paper Source
2-sided Printing
Multi-purpose Tray
Drawer 1
Drawer 2, 3 (optional)
Plain paper*2 (16.0 to 19.8 lb Bond (60 to 74 g/m²))
[Plain L]
A4
B5
A5*8
A6
Legal
Letter
Executive
Statement
Foolscap
16K
Custom size paper
*3 |
*4 |
*4 |
*5 |
Plain paper*2 (19.9 to 23.9 lb Bond (75 to 90 g/m²))
[Plain] (Default)
A4
B5
A5*8
A6
Legal
Letter
Executive
Statement
Foolscap
16K
Custom size paper
*3 |
*4 |
*4 |
*5 |
Heavy paper (24.0 to 27.9 lb Bond (91 to 105 g/m²))
[Heavy 1]
A4
B5
A5*8
A6
Legal
Letter
Executive
Statement
Foolscap
16K
Custom size paper
*3 |
*4 |
*4 |
*5 |
Heavy paper (28.0 lb Bond to 73.6 lb Cover (106 to 199 g/m²))
[Heavy 2]
A4
*6 |
*6 |
*6 |
B5
*6 |
*6 |
A5*8
*6 |
*6 |
A6
*6 |
*6 |
Legal
*6 |
*6 |
*6 |
Letter
*6 |
*6 |
*6 |
Executive
*6 |
*6 |
Statement
*6 |
*6 |
Foolscap
*6 |
*6 |
*6 |
16K
*6 |
*6 |
Custom size paper
*3 |
*4*6 |
*4*6 |
*5*6 |
Transparency
[Transparency]
A4
Letter
Label
[Labels]
A4
B5
A5*8
A6
Legal
Letter
Executive
Statement
Foolscap
16K
Custom size paper
*3 |
Index Card*7
[Envelope]
Index Card
Envelope
[Envelope]
Envelope Monarch
Envelope No.10
Envelope DL
Envelope ISO-C5
*1
The setting is located in the [Paper Source] tab in the printer driver. If you print from DOS, UNIX, or other operating system, specify a paper type in [Standard Paper Size] in the control panel.
*2
Recycled paper can also be used.
*3
You can load custom size paper that is 3.00 to 8.50 in. (76.2 to 215.9 mm) wide and 5.00 to 14.00 in. (127.0 to 355.6 mm) long. (If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long also in landscape orientation.)
*4
You can load custom size paper that is 4.13 to 8.50 in. (105.0 to 215.9 mm) wide and 5.83 to 14.00 in. (148.0 to 355.6 mm) long. (If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long also in landscape orientation.)
*5
You can perform 2-sided printing with custom size paper that is 8.27 to 8.50 in. (210.0 to 215.9 mm) wide and 11.00 to 14.00 in. (279.4 to 355.6 mm) long.
*6
You can use heavy paper of up to 44.4 lb Cover (120 g/m²).
*7
The following Index Card size is supported.
3.00 x 5.00 in. (76.2 x 127.0 mm)
*8
A5 size paper can also be loaded in landscape orientation.
The print speed may drop depending on the paper settings for the size, type, orientation, and number of copies.
The print speed may drop in the following cases.
- The short edges of the paper are less than 8.27 in. (210.0 mm).
- The long edges of the paper are less than 11.00 in. (279.4 mm).*
* Excluding cases when A5 paper is printed in landscape orientation
The envelope sizes are as follows.
Chlorine-free paper
Chlorine-free paper can be used with this printer.
