Canceling the Process Currently Being Performed (Soft Reset)
If you want to cancel the process currently being performed, perform [Soft Reset] using the following procedure.
The data that is being printed, that is on the print queue, or that is being received is deleted.
Performing a soft reset deletes all the jobs (those from other computers and interfaces).
Make sure that other users are not printing before performing a soft reset.
About the difference from a hard reset
Hard resets delete all the registered files, such as the form data saved in the RAM of the printer, but soft resets do not delete them.
1
Cancel printing from the computer.
2
Press [ ] (Reset).
3
Select [Soft Reset] using [  ] and [  ], and then press [OK].
Hold down the [OK] key 5 seconds or more if you want to perform a [Hard Reset].
4
Select [Yes] using [  ], and then press [OK].
When <Resetting software...> disappears, the soft reset is completed.
» Basic Printer Operations » Canceling a Job » Canceling the Process Currently Being Performed (Soft Reset)
08X4-03W
